I hooked my new raido and took out the ol factory .. okay so now i got my raido working but when i attempt to turn my raido up to a loud voluem it cuts off and startsx buzzing... can you help me with this problem?
bad ground or power supply would be my first guess. Every time I've had an amp or radio cut off at higher volume, it's because it couldn't get the power it needed.
You may want to check and make sure the polarity is correct on your speakers, meaning negatives with negatives and hots with hots , I recently had this happen in my wifes truck and the speakers hooked up wrong now you can crank it till the speakers blow lol , hope this helps .
reversing the polarity on the speakers won't cause cutting out, POSSIBLY it would with tweeters but I'm still skeptical there. Reversing the polarity just changes whether the speaker pushes or pulls. I used to compete in stereo comps, and lots of people will reverse them in different situations, some amps even have a switch to do it without swapping wires.
Ive thought about it, and ill try it, Im just tryin to narrow it down so ill spend less time workin on it and more time enjoying it thanks!
It could be a power feed issue, poor ground (amounts to the same thing), or your speakers are out of phase. You could have one speaker wired correctly and one speaker reverse. This will cause them to sound terrible when you turn it up.
When I installed a aftermarket stereo and started to have the same problem I thought it was the deck but it turned out to be that the speaker connection had come loose an was grounding out . just my 2 cents
well i tried revercing the polarity nothinhg, the weird thing is that the buzzing sound comes out of BOTH speakers well i guess ill try regrounding it andsee it that helps :/
