On board air for my highboy
I have been doing a lot of research on this subject an I have been collecting all the parts that I needed . I still have a few more things to get but it's time to start the project. I went to a place called Trade an Tools an bought a small compressor that had a bad motor, cost was $35 this provided the pressure switch, the gauges, air manifold, an of course the tank. I also got a york A/C compressor 210 model from the wrecking yard an I went to perform the oil modification but mine was already done. Here's the link
http://www.jedi.com/obiwan/jeep/york_oilmod.html
I still need to get all the lines an mount everything. This will take some time but I will get it done . Things I have done is to clean the mounting bracket for compressor an the crank pulley . Tear apart the small compressor an figure out where I'm going to mount everything . I did take some pic's of what I have now so here you go
Compressor bracket
That's all I have done for now ,must wait for payday to get the rest of the stuff .
Compressor bracket
I'm going to subscribe to this thread as I have been wanting to do this for some time, looks like you got a great start. What vehicle did you pull that compressor off of? I'm going to look around but most of the J.Y's around me don't have much in the way of older rides... I'm going to make some calls but don't know what year and models to ask for...
On board air
akforceten,Thanks for the tip on the oil modification,I run a york 10 with an exterior oilier and my pump gets real hot sometimes so that looks like it might fix that for me.I will probably keep the exterior oilier as I run a big oil and water separator now.For those who do not have the money to get a pressure switch you can use an old pressure switch from a residential well.I have a well for my water supply so I had a couple of used ones laying around,they are 220 volt AC but will handle DC 12 volts very well as mine has been on the truck for over ten years now. You will have to get a small fitting so you can hook up a 1/4" copper or plastic tube for the signal,I tried plastic for awhile but it would get to hot and pop at the main line so I just went with copper.Don't forget a 150 lb pop off valve as these compressors will blow your air lines if for some reason the switch gets stuck open.Hope this helps.
"bowties in the rearview mirror"
i also have a interior air preshure gauge and a manual over ride switch in the cab, i have pictures of my set up il post when i get home thursday
p.s. i would not recomend useing atf as a internal lube for the york i use rotilla SAE 30 or a oil meant specificly for compressor crank case lube
I'm subscribing as well as I've been planning on something similar & have the york a buddy gave me off his 76 F-250 to use. The difference on my setup is I am hoping to spin mine off the center driveshaft in my '74 highboy crew.
*edit* Here's another thread I had saved on this in case anyone here hasn't seen it.
https://www.ford-trucks.com/forums/1...board-air.html
chasetruck it would probably be easyer to run the york off a pto on the transmission. that way you wouldnt have to shift the Tcase into neutral everytime you want to run your york. i am verry interested to see your set up with the electric clutch.
hey guys its been a couple days i just got home from the mountains of NC and figured out my internet isnt working so im reouting my laptop through my phone :P
here are some pictures i promised earlyer, granted these were taken before i had a real manifold/splitter at the preshure switch and before i added my air horn il get out tomorow and take some pictures of the revised system
i used the factory A/C brakets for a 390 instead of fabbing my own........30 bucks at the pick n pull was well worth it i curently dont have any pictures of the tank and lines back to them il get some tomorow with the others
