I know the windows are the same from 73-96, but just wanted to make sure the window seals are also the same before I pull the window out. I pulled a nice slider from 94 with the rubber. This is going in my 77. Thanks
Use the rubber from the 94............ The difference is the groove in the rubber where the window fits, it will be a different width. I pulled a slider out of an 89 or so and used the rubber off of it and it worked perfectly in my 78.
