Ohio truck meet results and VIDEOS - Page 4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #46
Old 08-31-2011, 01:57 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Thumbs up
Quote:
Originally Posted by Eatonpcat View Post
I always get better mileage after a big dump...(Does that count)???
  #47
Old 08-31-2011, 03:34 PM
i eat hybrids's Avatar
i eat hybrids i eat hybrids is offline
i eat hybrids has a very good reputation on FTE.i eat hybrids has a very good reputation on FTE.i eat hybrids has a very good reputation on FTE.
Quote:
Originally Posted by 2000silverbullet View Post
Funny you mention that Matt, my mileage has increased around town after flogging my truck up that hill last weekend.
hahaha u sure it wasnt cause u were 15k lighter?? And i thought i was gonna have to do injectors. Funny thing is, i consider my 6.0 to be one of the reliable 6.0s. loll Only been in the shop twice in 120k.. Knock on wood
On and an update on the VSS, the CEL never came back up for that P0500 (VSS). So im not gonna change a thing
  #48
Old 08-31-2011, 05:59 PM
Dim Sum's Avatar
Dim Sum Dim Sum is offline
Dim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant future
I got 19.4 mpg round trip . (hand calc)
  #49
Old 08-31-2011, 06:01 PM
KC8QVO's Avatar
KC8QVO KC8QVO is offline
KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.
When you run engines hard shortly after new it helps to seat the rings and merry all the moving parts together. This contributes to better fuel mileage. Although, some on here have mentioned that there is a bit of a correlation to less fuel mileage on diesels after break-in due to the DPF getting worked in. I am not quite sure what to make of that... Though I am glad I got to give my engine a good hard run. I don't get to work it that hard on a regular basis so a good blow-out can be a good thing once in a while.
  #50
Old 09-01-2011, 10:32 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
Attached is a PDF with the results.
Millersburg, OH meet results on August 28, 2011.pdf
Edit: Fixed issue in Special Notes.
  #51
Old 09-02-2011, 06:14 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
Quote:
Attachment 40899
This is cool, thanks Mike.
FYI - Special notes on mine is incorrect, I have 6500 miles on the truck (Dim Sum's truck only had 1k on it).
  #52
Old 09-02-2011, 08:11 AM
Monster-4's Avatar
Well crap. Strike two. I will correct it here in a bit.
EDIT: Results PDF has been updated again.
  #53
Old 12-08-2011, 01:47 PM
fordtruckf-100 fordtruckf-100 is offline
fordtruckf-100 is starting off with a positive reputation.
So i am comparing a 6.2L Gas and i have a 6.0L Diesel now. I pull 2 tractors (a total of 15,000lbs) to tractor pulls around the area, and my 6.0L did fine but not happy with the maintenance costs. Looking into a 6.2L gas. What do you think? Will she pull it?
  #54
Old 12-08-2011, 05:15 PM
Monster-4's Avatar
I don't own a 6.2 (I still have my ancient V10 PI 2V) but if you look at the PDF I made in the post above you see that the 6.2 with 4.30's we tested was nearly has fast as the 6.7 PSD. We were towing 15K up a pretty good incline so it gives you a good idea what it can do. I have little doubt the 6.2 could hang with the 6.7 (high altitude where air is thinner comes to mind as a sure win for the 6.7) in many situations and it probably can outpace a 6.0 in many of them.
The 6.0 we tested is not a good indication of performance since it was having boost issues. Found out later the turbo was leaking pretty badly and on top of that it was also having VSS issues.
I was very impressed with the 6.2 that day. I was not a fan since Ford did away with my beloved V10 in the F250/F350 but I changed my tune after that day. If you were towing 15K every day and needed to make a living then the PSD would make more sense from a fuel mileage standpoint. However if you are towing 15K once in awhile I would not be afraid of getting a 6.2.
  #55
Old 02-05-2012, 05:15 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Thumbs up
Quote:
Originally Posted by raidscsi View Post
Also what tablet/application were you using to read the (OBD?) data?
The App = Torque
It's an Android app...
GREAT job guys! Enjoyed watching the video's...
biz
  #56
Old 02-05-2012, 05:19 PM
jmahle67 jmahle67 is offline
jmahle67 is starting off with a positive reputation.
any plans for any meets coming up soon?
  #57
Old 02-06-2012, 08:18 AM
Monster-4's Avatar
Yes. I'm trying to get one put together for late April, early or mid May. I'm trying to come up with a date this week.
  #58
Old 02-06-2012, 08:33 AM
senix's Avatar
keep us posted maybe I can make it for that one.
  #59
Old 02-06-2012, 09:00 AM
I would love to be able to make a meet. I look forward to meeting some super duty guys. I was in w the ranger crowd before but haven't met anyone around here w a super duty yet.
  #60
Old 02-06-2012, 08:02 PM
I'll make sure to keep that window open, would like to make it.
2013 Millersburg Meet results with HD video! Tom 1999 to 2016 Super Duty 143 05-18-2016 06:14 PM
Why does everyone complain about the rear springs? (UPDATED with more weight) Tom 2009 - 2014 F150 17 09-06-2013 11:26 PM
Ohio truck meet results and VIDEOS Tom 6.7L Power Stroke Diesel 84 10-05-2011 08:31 PM
Ohio truck meet results WITH VIDEO! Tom 1999 to 2016 Super Duty 47 01-26-2011 11:41 PM
Ohio truck meet results WITH VIDEO! Tom Modular V10 (6.8l) 50 01-13-2011 12:53 AM
Tags
00, 11, autos, axle, cab, con, crew, dump, f250, f350, f550, ft, holds, specs, trailer, tuneado, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
