Check Gas Cap Light On
Old 08-29-2011, 07:32 AM
SenZBar's Avatar
SenZBar
SenZBar is offline
Hi All,
I just purchased a 2004 X with 93 K on the V10. Been driving it a few weeks (Loving it) and yesterday the check gas cap came on after stopping for 20 min (I did not touch the cap).
I realize this may be more than just the cap but would like trouble shooting assistance. I removed the cap checked the O ring and all seems good. Since the light did not come on after fueling I don't think its the culprit.
New to the Excursion so some tips on what/Where to look for the DIYer. Also what is tghe procedure to clear the light? Remove battery lead or will it clear after some cycles?
Thanks to all...
Old 08-29-2011, 01:05 PM
tdappleman's Avatar
tdappleman
tdappleman is offline
The system does not necessarily do a evap test on each drive cycle so it could have still be after fueling up. Once they get some age they do not hold the same pressure even if the o-ring appears to be good. If it went off it is most likely ok and just wasn't seated all of the way or maybe had dirt in the seal. If it comes back you can have the evap system tested by someone with a scan tool or just replace the cap as it will be the first thing most shops will suggest.
tmaglin
1999 to 2016 Super Duty
03-01-2018 10:45 PM
ToolTime
11-04-2012 01:27 PM
78'fordtruckguy
04-12-2010 01:59 PM
1984F15016
01-23-2008 05:55 PM
bartamos
1997 - 2003 F150
17
12-13-2006 03:16 PM
Quick Reply: Check Gas Cap Light On
