Check Gas Cap Light On - Ford Truck Enthusiasts Forums
Old 08-29-2011, 07:32 AM
SenZBar SenZBar is offline
SenZBar is starting off with a positive reputation.
Hi All,
I just purchased a 2004 X with 93 K on the V10. Been driving it a few weeks (Loving it) and yesterday the check gas cap came on after stopping for 20 min (I did not touch the cap).
I realize this may be more than just the cap but would like trouble shooting assistance. I removed the cap checked the O ring and all seems good. Since the light did not come on after fueling I don't think its the culprit.
New to the Excursion so some tips on what/Where to look for the DIYer. Also what is tghe procedure to clear the light? Remove battery lead or will it clear after some cycles?
Thanks to all...
Old 08-29-2011, 01:05 PM
tdappleman tdappleman is offline
tdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to all
The system does not necessarily do a evap test on each drive cycle so it could have still be after fueling up. Once they get some age they do not hold the same pressure even if the o-ring appears to be good. If it went off it is most likely ok and just wasn't seated all of the way or maybe had dirt in the seal. If it comes back you can have the evap system tested by someone with a scan tool or just replace the cap as it will be the first thing most shops will suggest.
Trouble code PO442 tseekins 1997-2006 Expedition & Navigator 10 04-07-2015 02:30 PM
How to remove locking gas cap? DieHardChief 1973 - 1979 F-100 & Larger F-Series Trucks 9 11-05-2013 10:41 PM
gas cap light stays on all the time...on my 04 f250 78'fordtruckguy 1999 to 2016 Super Duty 5 04-12-2010 01:59 PM
04 F250 gas cap light/check engine light ctguy 1999 to 2016 Super Duty 5 02-05-2009 12:53 PM
P1450 DTC Code - 5.4L 2V V8, cargo van metrovic Modular V8 (4.6L, 5.4L) 0 09-06-2006 06:27 AM
Tags
2001, 2003, 2005, 2006, cap, check, escape, explorer, f150, ford, fuel, gas, light, ranger, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
