2003 Explorer A/C vent temp - Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Old 08-28-2011, 11:47 PM
riddleswest riddleswest is offline
riddleswest is starting off with a positive reputation.
My wifes explorer started doing something strange. The a/c vents on the drivers side are intermittently not blowing cold while the vents on the passenger side work fine. The airflow seems to be even but the temp is definitely not. Could this be a blend door problem?
A/C not blowing out passenger vent raye321 1968-2013 Full Size Vans 1 08-01-2014 06:20 AM
another blend door problem? dartguy699 Explorer, Sport Trac, Mountaineer & Aviator 2 03-21-2012 10:02 PM
2003 Explorer A/C problem riddleswest Explorer, Sport Trac, Mountaineer & Aviator 2 08-30-2011 10:31 AM
A/C and heat not working in rear vents sombionix Cooling, Heating, Ventilation & A/C 1 06-04-2007 08:43 PM
A/C operation oshoguno Cooling, Heating, Ventilation & A/C 4 07-01-2003 04:53 AM
Tags
1996, 2003, ac, blowing, explorer, f150, ford, hard, hot, systems, temperature, truck, vent, ventilation, ventilator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
