4r70w extention housing - Ford Truck Enthusiasts Forums
Old 08-28-2011, 11:07 PM
eric f150 eric f150 is offline
eric f150 is starting off with a positive reputation.
i have a 98 f150 4.6 auto 4x4
the problem it the extension housing is cracked all the way around.
i have an older mazda 5speed trans kicking around from a 96 f150 and im wondering if the tail stock off that will fit on the 4r70w.
i would just pull it off and check it out, but the problem is i cant leave the truck disabled in the shop at work, but i dont want to spend the money on a new one if mine will work.
thanks for any help
98 f 150 4.6l with 4r70w trans keeps breaking flexplates roughneck621 1997 - 2003 F150 3 12-03-2013 10:06 PM
EXCHANGING A 4R70W WITH A 4R70E TRANSMISSION CMGALLAMORE 1997 - 2003 F150 7 09-23-2012 12:40 AM
bell housing question wahl7s 1997 - 2003 F150 5 03-18-2011 01:06 PM
towing with a 4R70W lumprsmith F150 Clutch, Transmission, Differential, Axle & Transfer Case 3 05-04-2010 05:52 AM
4r70w to 1345 tc Diamond Jim Clutch, Transmission, Differential, Axle & Transfer Case 2 02-14-2006 12:31 PM
Tags
2003, 2005, 4r70e, 4r70w, cracked, excursion, extension, f150, ford, housing, tail, tailhousing, triton, trucks, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
