Codes Help! 1994 F150 Help Video!
TRUCK IN SIG!
This thread goes for my other thread here.
After viewing the videos, help me diagnose my problem as stated
in the thread provided!
https://www.ford-trucks.com/forums/1...-injector.html
KOEO
<iframe width="640" height="510" src="http://www.youtube.com/embed/WI5l0b7u3qE?rel=0" frameborder="0" allowfullscreen></iframe>
This is the video I made while trying to pull codes. (About 3rd time I've pulled codes, so I made video to double check myself)
Codes: 522, 173
KOER SKIP TO 1:15
<iframe width="640" height="510" src="http://www.youtube.com/embed/9Qd0s8mRjvA?rel=0" frameborder="0" allowfullscreen></iframe>
Also another video I made while pulling codes.
Codes: 116, 173
Did I get it right? Also I need help knowing what they are! My symptoms are in the thread above!
KOEO
Codes: 522, 173
KOER SKIP TO 1:15
Codes: 116, 173
Yes you got it right except the first 173 is not a KOEO code it is a CM code.
KOEO 522
CM 173
KOER 116 & 173
KOEO DTC 522 Clutch not in during test.
CM 173 & KOER 173 system indicates rich.
KOER DTC 116 (ECT) indicates that the corresponding sensor is out of Self-Test range. Correct range of measure is 0.3 to 3.7 volts.
Possible causes:
-- Low coolant level (ECT).
-- Faulty harness connector.
-- Faulty sensor.
OR Cold Engine.
KOEO 522
CM 173
KOER 116 & 173
Possible causes:
-- Faulty sensor.
OR Cold Engine.
No it wasn't at operating temp. I just started it up and started scanning. Ok so I know 116 and 522 would be gone if I had held the clutch and if it was at operating temperature.
Just gotta replace the exhaust system and O2 sensor so it'll stop running rich I'm guessing.
If you see any fuel at all it is bad and will cause a rich code and poor running.
I will check that hose later tonight.
Also which is the FPR?
Which is the EGR? My hose isn't green. I'm going to do that restrictor plate.
Ok I will test that tonight. Ran the codes for CEL and they were the same, but without 116. I even held the clutch in and I still got 522?
Also I just went over to my muffler shop and they checked out my system and said I have a crack/leak on the manifolds but catback looks great. Also my cats aren't clogged.
So I'm thinking I'm gunna upgrade to these Hedman Hedders, while I'm at it.
Hedman Hedders 89300 - Hedman Street Hedders - Overview - SummitRacing.com
Guess I just have to check the FPR and the O2 sensor.
So I'm understanding that if the I can see fuel coming from the nipple of the FPR then that's bad. So IF that does happen, do I replace the FPR?
Ok sorry for the wait. But I finally had my truck off long enough for it to be considered cold. And while the light was up!
Anyways, the FPR did not leak any fuel. So it checks out. So I am planning on doing that EGR restrictor plate.
Also, I am pretty sure the truck has the original timing belt in it, so with all the play the engine has gotten, could it be possible this is the culprit? But I still don't see how it would be "fixed" every time I turn it off/on.
Will be buying a new O2 sensor just in case.
