4.6L spark plug issues???? - Ford Truck Enthusiasts Forums
Old 08-28-2011, 09:43 PM
bigunit54's Avatar
bigunit54 bigunit54 is online now
bigunit54 is gaining momentum as a positive member of FTE.bigunit54 is gaining momentum as a positive member of FTE.
hi guys,
My wife and I are looking at replacing her 05 liberty with an 06 explorer. Well I was just in the explorer forum and found a thread talking about the same two-piece plug design and breakage issues that us with our 5.4s have had to deal with. Well, I thought I had read in this forum that the 4.6L didn't have this problem. Did they put a different version of the 4.6 in the explorer than the f-150? I guess I need to know this so if it is a problem I can try to negotiate the plug change as part of the trade(it has 82,000). Thanks guys for any answers.
Old 08-28-2011, 10:10 PM
vloney vloney is offline
vloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant future
Its just the 5.4 3 valve.
Old 08-28-2011, 10:40 PM
bigunit54's Avatar
Ok, here's a link to the thread. It just really confused me because I thought the 4.6L had a regular plug in it.
http://www.ford-trucks.com/forums/10...questions.html
these guys are talking about the same problems the 5.4 plugs have but in the 4.6L. What gives??
Old 08-29-2011, 07:04 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
The Explorer 4.6L has 3 valve heads which may have the same problem as the 3 valve 5.4L. Until recently the truck 4.6L only came with 2 valve heads.
Old 08-29-2011, 07:37 AM
bigunit54's Avatar
ok thanks. So if it is a 4.6L3V then it probably has this problem.
4.6 vs 5.4 Spark Plug Problems SC_Hoaty Modular V8 (4.6L, 5.4L) 10 12-12-2013 11:34 PM
2006 Explorer 4.6 spark plugs and ticking BLK94F150 Modular V8 (4.6L, 5.4L) 1 06-04-2012 08:11 PM
Spark Plug Blowout Terry Huval Explorer, Sport Trac, Mountaineer & Aviator 5 12-30-2010 04:36 PM
4.6 3 valve reviews jrank 2009 - 2014 F150 4 12-21-2009 07:23 PM
Does the 3-valve 4.6 have the stuck plug problem? YoGeorge Modular V8 (4.6L, 5.4L) 1 11-06-2008 08:29 AM
Tags
04, 2007, 2008, 46, 46l, change, explorer, f150, ford, plug, plugs, problems, spark, stuck, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
