2007 F150 Cabin Blower Problem
Hi
I did several searches using the keywords that make sense to me, and found nothing about the problem with my '07 F150 super Crew.
I thought I had an after market service manual, but I guess not and I'll have to get one.
The other day, I noticed that the cabin blower works fine on speeds 1, 2 & 4 but while on speed 3, it blows the same as speed 2.
Based on some of what I read, it seems the different speeds simply switch between different series resistors. That being said, unless the speed-3 resistor increased to a similar value as speed-2 (which seems a bit unlikely) I'm a bit confused about this malfunction.
Also, where might I find this speed control board?
Any help would be appreciated..
Thanx
Thanx
I had the same problem but it was #1 speed that wasn't working . It's an easy fix, the circuit board is about $30 and it is located on the passenger side down at the fan motor. You will see an electrical connector with 2 screws. Simply unplug it and remove the screws and install the new circuit board. If you search I think there is a forum that explains it with pictures. Good luck !
