F450 vs F350 Differences? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-28-2011, 05:20 PM
DenaliHD66 DenaliHD66 is offline
DenaliHD66 is starting off with a positive reputation.
Other than a wider front track, slightly upgraded trailer hitch, and 4.30 axle ratio, are there any other stock differences? I didn't see anything about the suspension being different, and both trucks are still upgradeable to a heavy service front spring set.
Old 08-28-2011, 05:23 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
Wheels are 10 lug, frame is different, axles are different.
Old 08-28-2011, 05:30 PM
dualwheels66 dualwheels66 is offline
dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.
Are you talking about pickup 350 vs 450 or cab and chassis 350 vs 450?
Old 08-28-2011, 05:49 PM
pickups, both dually.
Old 08-28-2011, 05:56 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
The difference? About $20,000?
Old 08-28-2011, 06:09 PM
nah, exact same setup and options is about a difference of 3-4k. talking about the new 2011/2012 ones by the way. the 19.5" wheels on the last f450's made it look so much more badass, but the new ones probably give a better ride/speed rating.
Old 08-28-2011, 06:12 PM
ok i'm seeing that the F450 has almost 2" in diameter larger brakes too. i think the new ones only are 8 lug wheels though.
Old 08-28-2011, 07:28 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
The big differences is the chassis. It's gonna ride harder and has a beefier frame. Also, you can get longer frames and wheel bases. But that's only on the chassis cab.
Old 08-28-2011, 07:42 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
the difference is 100
Old 08-28-2011, 10:49 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
350 and 450 pickups have the same chassis.
Both have the Dana 80 rear axle rated at 9000 lb. GAWR.
Both have a 6000 lb. GAWR for the front axle but the 450 has the Dana Super 60 Monobeam Widetrack axle.
450 has larger brakes.
350 has a higher payload rating and the 450 has a higher tow rating.
350 has a 3.73 axle ratio and the 450 has the 4.30.
The 350 is available in 2WD or 4WD and the 450 is available only as a 4WD.
Both the 350 and the 450 have 8 lug wheels.
https://www.fleet.ford.com/truckbbas...ckup_specs.pdf
This is based upon the 2011 model pickup info. The chassis-cabs are different. Although, after looking through the 2012 order guide, there don't appear to be any changes with regard to the differences between the 350 and 450 pickups. And the above is basic standard info. not taking into consideration optional packages such as the Snow Plow Package or the Heavy Service Front Suspension Package.
Old 08-28-2011, 10:58 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Ford basically turned the F-450 (with the bed) into an F-350 with a higher rating for 2011. Not as much difference between the 350 and 450 as was with the 2008-2010 models.
Old 08-29-2011, 11:32 AM
jaybread jaybread is offline
jaybread is starting off with a positive reputation.
Brakes
BRAKES
Type 4-wheel vented-disc ABS (standard)
Front (rotor diameter) 13.66" (F-250/F-350); 14.53" (F-450)
Rear (rotor diameter) 13.39" (F-250/F-350); 15.35" (F-450)
Old 09-03-2011, 02:02 PM
Yeah I didn't think there were many major differences in the new models, as opposed to the older models. Just didn't know if the chassis was any different, but my question was answered in this thread. Can you get an E-locker for the duallys that engages the same way as SRW trucks by pulling out the 4WD selector switch?
Old 09-03-2011, 03:34 PM
The F450 frame has extra reinforcing compared to F350. They are not identical.
Old 09-03-2011, 03:56 PM
i eat hybrids's Avatar
i eat hybrids i eat hybrids is offline
i eat hybrids has a very good reputation on FTE.i eat hybrids has a very good reputation on FTE.i eat hybrids has a very good reputation on FTE.
Quote:
Dont see why theyd downgrade on the rims... Not like ppl need to do over 90 mph in a 10k F450 anyways . Those 19.5 were mean lookin and made the truck
Also dont forget they detuned the new 6.7s in the chassis cabs and used a diff turbo.
03 F -250 Upgrade Fhernandez319 1999 to 2016 Super Duty 1 10-11-2015 09:56 PM
ZF6 upgrade swade-o Clutch, Transmission, Differential, Axle & Transfer Case 2 01-11-2012 11:00 PM
F 350 vs F450 crazer42 6.7L Power Stroke Diesel 26 12-22-2010 02:09 PM
Factory radio replacement ? rlivin 1999 to 2016 Super Duty 4 09-05-2009 08:25 PM
Part Numbers for ECM Why different/? 69crewcab 1999 - 2003 7.3L Power Stroke Diesel 1 08-31-2004 12:14 AM
Tags
10, 1996, 2011, 350, 450, 67, difference, f250, f350, f350f450, f450, ford, lug, specs, vs, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
