Speed Limiter??? - Ford Truck Enthusiasts Forums
Speed Limiter???
Old 08-28-2011, 04:12 PM
now_exowner now_exowner is offline
now_exowner is gaining momentum as a positive member of FTE.
Speed Limiter???
I've found my first disappointment with my truck.....what is up with the speed limiter at 95??? I witnessed a Chevy HHR sideswipe and run on an interstate....well, being the good samaritan I am and thinking that I should have NO problem running him down with the 5.0. So I hit #77 and get MSP on the line, I was charging hard I ran it up and hit the limiter....how dissapointing!!! I did get close enough to get the tag and imagine he got what was coming to him....looks like it's gonna be time for a tune....
Old 08-28-2011, 05:11 PM
Chris Anchor's Avatar
Chris Anchor Chris Anchor is offline
Chris Anchor is gaining momentum as a positive member of FTE.Chris Anchor is gaining momentum as a positive member of FTE.
I'm surprised that MSP didn't give you a ticket for speeding. Reveune is down in the state, just ask the O'Money.Chris
Old 08-29-2011, 08:41 AM
shortride's Avatar
shortride shortride is offline
shortride is gaining momentum as a positive member of FTE.shortride is gaining momentum as a positive member of FTE.
Quote:
I'm sure your efforts were appreciated but I would not defeat the speed limiter while under warranty if it were me. How many times do we need to go 95 mph?
Old 08-29-2011, 08:03 PM
blueovelboy's Avatar
blueovelboy blueovelboy is offline
blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.
Quote:
every time you have to poop and stuck out in town! wont use a public restrooms i got to have homefield advantage.
Old 08-30-2011, 07:21 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Quote:
LMAO!
Old 08-30-2011, 12:56 PM
ddrumman2004 ddrumman2004 is offline
ddrumman2004 is gaining momentum as a positive member of FTE.ddrumman2004 is gaining momentum as a positive member of FTE.
LOL! Sounds like me!
Getting old is tough.
But anyway, I haven't pushed my Ecoboost to see how fast she will run but the 97 F150, 4.6 auto I used to own would top out at a little over 100 mph. I have slowed down some in my start of my golden years.
Old 08-30-2011, 04:31 PM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
Good stuff!
Old 08-31-2011, 12:33 AM
640 CI Aluminum FORD 640 CI Aluminum FORD is offline
640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.
Speed limiters are odd little devices.
My family bought a 2004 F-150 4.6L Regular cab brand new back in 2004, and it would top out at 105mph. Then a few years later we traded the 2004 for a 2006 Extended cab with the same 4.6L V8 and it would top out right at 100mph.
Now I own a 2011 FX4 Supercab with the 5.0L and I took it to the governer the other day just to see what it topped at and it went to right at about 100mph ''like our 2006 F-150''.
And you say yours tops out at right around 95mph. Seems as though every truck is a little different. And like has already been said, how often do we really need to go at or past 95mph anyway...Other than when we really need to poop.
Old 08-31-2011, 05:20 AM
shortride's Avatar
I take it you didn't see the humor in that either.
Old 08-31-2011, 07:08 AM
tseekins's Avatar
Then why doesn't the speedo just stop at 100? At this point in my life I couldn't imagine driving 95 in my truck though I regularly cruise at 80 if traffic allows.
Is this a federal mandate or a manufacturer installed device to save the drive train from us?
Old 08-31-2011, 01:57 PM
Brokebrute Brokebrute is offline
Brokebrute is starting off with a positive reputation.
It's set at the lowest speed rated tire they put on the truck at the factory.
Old 09-03-2011, 10:01 PM
wwilson43 wwilson43 is offline
wwilson43 is starting off with a positive reputation.
I have a 10 with the 4.6 2V and it topped out at 100
Old 09-03-2011, 10:32 PM
Gary Atsma Gary Atsma is offline
Gary Atsma is gaining momentum as a positive member of FTE.
My '03 F-250 w/6.0 Diesel pulls the plug @ 95mph. Nothing gradual, either. I'll be accelerating like a Saturn rocket right up to 95, then OOPS!..... that's as good as it gets! But others said it right; how often do we get above 95mph? Be kinda cool to check out the actual "upper limit" once in a while, though.......
Old 09-04-2011, 04:49 PM
JesseJFX2 JesseJFX2 is offline
JesseJFX2 is starting off with a positive reputation.
Quote:
This... It's a safety measure taken by most auto manufacturers, typically electronic "limits" are set 5 to 10 mph below the speed rating on the lowest rated tire equipped on that model vehicle. Interesting tidbit of info, there are WAY more different tire sizes programmed into the comp in a single vehicle, for instance, I just put slightly larger tires on my 2010 XLT 4x2 and there where 7 different size calibrations in the computer for the Ford dealer to choose from.
Old 09-04-2011, 06:32 PM
I'm not a humor's person.
ELocker vs. Limited Slip BII Plow Truck 2017 Super Duty 20 08-27-2016 08:42 AM
Axle gearing for 79 F250 4x4 apachetech 1973 - 1979 F-100 & Larger F-Series Trucks 5 09-01-2015 10:41 PM
Does this happen to you? IronCobra 6.7L Power Stroke Diesel 31 08-20-2015 10:56 PM
Removing speed limiter without a tuner? 2006powerstroke90 6.0L Power Stroke Diesel 6 09-04-2011 08:48 PM
Is it possible to remove the speed limiter?? shanksyamaha 1999 to 2016 Super Duty 25 04-08-2009 11:15 PM
Tags
130, 1999, 2000, 2011, 94, company, disable, expedition, explorer, f150, ford, governor, lightning, limiter, motor, mph, speed, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
