Foundation crack (vertical)...earthquake?
It looks like the left side has sunk! What does the floor look like? Can you put a level on the floor and see if the air bubble goes UP to the RIGHT any? I am not a structural engeneer and I did NOT spend the night in a Holiday Inn Express last night but that does not look good from here.
Is that a masonry wall??? Looks like the mortar joints are not staggered (that's not good). but maybe I am looking at it wrong. It is a pretty bad picture.
I agree with Copedawg said...If the picture is a true view and it is sloping down to the left, you have some issues. Somebody suggested a crack monitor and that is a good idea.
A structural Engineer in your area will look at for a few Hundred bucks. If you just fill the crack and it is still moving, you will not have accomplished anything. Good Luck!
I don't claim to be a structural engineer but what I see from the picture is nothing I would be overly concern about in that it has not opened a gap or shifted. Cracks like that are common in masonry walls. My guess is that brick you see if fascia brick and not structural. Won't hurt to put some epoxy as recommended. Look farther in the area for other signs of shifting walls, etc and monitor.
I'll do some more research and keep my eyes on that spot.
Those aren't bricks. The concrete forms that were used are imprinted with the brick look.
As far as the crack is concerned, if it hasn't cracked all the way through to the inside. You can just drill a hole at both ends of the crack to stop it from going any further. Then bevel out the crack with a chisel or grinder. Then get a caulking tube of crack filler made by Quick Crete and squeeze it into the crack. and wet your finger and smooth out the filler and you're done.
Ask This Old House recently did a segment on a real bad foundation crack, so you may go to their website and have a look at it.
I'll check that out.
Do you mean 3" x 3" ? The crack itself is maybe a foot long. I'll see if I can do that tomorrow morning. I'll have to find the wifeys camera. The Blackberry camera didn't cut it.
I should have probably said this the first time I posted…I know everyone (and rightly so) are very leery of getting insurance involved early or at all.
My view on this ....it is calculated risk, if you ever wanted to sell the house you will need an inspection, then if the inspector is trying to cover his career…he will suggest a structural engineer to look at it........ then sale is pending until you get a clean bill of health or it is fixed…if it is done now you have a record fixed correctly or …..a statement saying no need to worry…
Again only saving issues latter on and in a market that is buyer driven…too many option for someone to walk away at the littlest of issues...perceived or real
I just bought the house last year. That's something I won't have to worry about for a while (knock on wood).
Here's how it looks from a few feet away (with the $h1tty cell phone camera). Again...I'm not sure what's up with the distortion of the camera. There doesn't appear to be an issue (other than the crack) firsthand.
#29
How old is the house? To me, it looks nothing more than a normal crack that is not below the surface (not deep). I don't think it is anything to worry about. If your that concerned about it, use some marking paint and keep an eye on it to see if it gets longer or wider. I work construction and see bigger cracks than that in new homes.
#30
