1989 F-150 Timing...HELP - Ford Truck Enthusiasts Forums
Old 08-27-2011, 06:44 PM
Savie1989 Savie1989 is offline
Savie1989 is starting off with a positive reputation.
Exclamation 1989 F-150 Timing...HELP
I have a 1989 F-150 4x4 with the 351W in it. I recently upgraded the ignition with MST Coil, Distributor,wires, K&N cool air Intake, Headman Headers and Flowmaster Exhaust. Since then i have not been able to tune it or get it timed correctly. I also noticed that the timing scale with the advance markings that is suppose to be mounted to the engine block is unlike ive seen before it has no markings to aid in timing. i can get it running good at high rpm and it dies sometimes at a light or stop sign. Or it runs like crap misfires and is very slugish Does any other owner of a truck like mine have any info that could help me out.
Old 08-27-2011, 07:13 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
The timing marks are on the balancer , you will need to clean it off good , then highlight the 10 deg BTDC mark so its easy to see , remove the spout then set the base timing , a few deg advanced will help performance...Lew
Old 05-04-2014, 11:07 AM
Richard Collachi Richard Collachi is offline
Richard Collachi is starting off with a positive reputation.
Do you know where the single black wire that you have to disconnect before setting timing on a 85f150 is located any help would be greatly appreciated thx
Body/Chassis Swap 1989 E150 to Quigley Chassis. Redinwolfe 1968-2013 Full Size Vans 30 06-05-2016 07:54 PM
1989 F-150 Differential bolt Pegstruck 1987 - 1996 F150 & Larger F-Series Trucks 4 01-05-2016 06:39 AM
Thinking about 1990 7.3 diesel conversion Mhintlian Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 01-04-2015 09:54 AM
1989 F-150 fuel tank selector valve 993/4ton 1987 - 1996 F150 & Larger F-Series Trucks 1 12-25-2008 10:15 PM
Manual transmission Kane150 1987 - 1996 F150 & Larger F-Series Trucks 9 07-09-2007 08:19 AM
Tags
1989, 406, f150, ford, marks, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
