Door Hinge Question - Ford Truck Enthusiasts Forums
Door Hinge Question
Old 08-27-2011, 01:31 PM
Kecky's Avatar
Kecky Kecky is offline
Kecky is starting off with a positive reputation.
Door Hinge Question
I am having trouble fitting my passenger door on my 56. Does anyone know if the hinges are left and right? They look interchangible but if they are left and right it might explain some fittment problems. (The door is soooo out of alignment it won't close when the hinge bolts are tightened down). I have reamed out the holes on the hinge to increase adjustment too. I know the factory manual shows the door being "bent" with a type of clamp to align but right now it won't even close. The hinge pocket in the cab looks ok. The hinge face on the door where the hinge bolts on doesn't look bent either.
I have a door from one vehicle, cab and then hinges from a third donor. I think they are interchangible but when you look to buy a hinge at mid-fifty or similar site they show a left and a right hinge.
Just curious if anyone has some insight?
Thanks
Kevin
Old 08-27-2011, 01:35 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
2) BAAA-8122800-A .. Right Upper & Lower Door Hinge.
2) BAAA-8122801-A .. Left Upper & Lower Door Hinge.
Applications: 1953/56 all trucks.
Re-hanging doors can be a real b!tch...especially if removed when the vehicle was on jackstands, then re-installed when it's on the ground.
I made this mistake...once! I spent five days re-hanging doors on a '55 T-Bird, chipping the he!! out of the fresh paint during the process.
Old 08-27-2011, 01:59 PM
Kecky's Avatar
Thanks for the quick reply and part numbers. Do you know if they are actually different hinges for each side though or just different part numbers for the same part?
Kevin
Old 08-27-2011, 02:04 PM
Quote:
Kevin
The part numbers are different because the hinges are specific to either the right or left side.
Upper/Lower is the same, but Right/Left makes a difference.
If all four hinges were the same, there would only be one part number.
Are all year Crew Cab rear hinges the same? El Campo 1999 to 2016 Super Duty 7 12-30-2014 08:36 PM
Door hinge interchange 98 Explorer Mikeman Explorer, Sport Trac, Mountaineer & Aviator 0 08-18-2014 09:51 PM
FAQ - Door hinge replacement that went well Roamer '80-'86 FAQs (Frequently Asked Questions) 7 05-08-2009 07:46 PM
Door hinge replacement that went well Roamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 05-08-2009 07:46 PM
Rear Hatch Alignment chrison600 Excursion - King of SUVs 1 05-18-2003 08:51 PM
Tags
55, 56, alignment, difference, door, f100, ford, hinges, left, tbird
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
