Programming PATS key with AutoEnginuity - Page 2 - Ford Truck Enthusiasts Forums
Old 05-20-2012, 08:07 PM
Locksmith1 Locksmith1 is offline
Locksmith1 is starting off with a positive reputation.
Video has been made and I wrote this EMAIL to them.
Hi...
I have been continueing to try to program PATS keys on my ford truck without any luck. I searched some ford forums on the internet and it seems as there are alot of people having the same problem and your answer to them is that the problem is with the vehicle. One man had this same problem, you explained that it was his truck and not the AE product. He then went to the dealer and got a key programmed with the ford NGS system.
I have tried all weekend long to program a second key without any success, I borrowed the Programming machine from my work ( Im a locksmith ) and it was successful at programming the 2nd PATS key.
With the other people having this issue ( 2002, 2003 and 2004 F150 ) and myself having the same issues ( 2001 excursion ) and error messages as the others, It has become obvious it is not the vehicles but something related to the Software / hardware or perhaps a compter setting.
I have video taped the Failure of the AE system while programming the PATS key and the Sucess of the Silca TKO system on the same vehicle and PATS key. Therefor it can not be anything that is vehicle related. Due to the size of the Video ( 1.16 GB Compressed ) I am unable to attatch it to an email. The video is long as it does show the AE displaying error messages, then attempting to gain security access to the vehicle and then fails with error messages again, followed my the Silca TKO machine going thru the security timer and programming the key. Upon your request I will upload it to youtube for you to see.
I look foward to your quick response and the correction of this problem.
I hope the youtube may be the kick in the pants they need to fix this issue. Ill keep you posted
Old 05-21-2012, 10:33 AM
I spoke with bill @ AE ... He corrected me in the steps to program the keys... Going to try again tonight. What he said made sense to me, so I will try that.
Old 05-21-2012, 10:48 AM
Farmerscot Farmerscot is offline
Farmerscot is starting off with a positive reputation.
Great! What did he say to do different? I'm looking forward to hearing the results.
Old 05-21-2012, 10:51 AM
I'll get right back 2 u !!
Old 05-21-2012, 11:05 AM
Is there an option for pvt msging ?? Send me you nmbr.. Too much to type on phone
Old 05-21-2012, 11:19 AM
Email your phone number to me at mikeTheKeyGuy@gmail.com
As it turns out there are two ways of doing this.. Too much to type from phone
Old 05-21-2012, 01:47 PM
Ok... I won't b home for a few hrs to try it... If you try it before me, let me know if it works.. I'll try it and post my findings later tonight ...nice talking with you Scott
Old 05-21-2012, 02:44 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
This ain't Twittter or Facebook. No need to give frequent updates.
When you're done, give a complete report.
Old 05-21-2012, 03:41 PM
Out of curiosity, what diff does it make ?
Old 05-21-2012, 05:09 PM
Thanks for the call, I did what you said they told you to do "leave the one programed key in until prompted to insert the unprogrammed key" it still came up with the same response. "key not programmed due to system busy or refusal". I hope you had better luck.
Old 05-21-2012, 11:14 PM
Talking
I GOT IT !
Old 05-22-2012, 01:02 AM
OK I worked thru it and I was successful at Deleting all keys and programming new ones. This is what worked for me, I have done it several times to verify my instructions here are correct. I wrote down step by step what I did the then I did it again and again as not to foward inaccurate info and waste peoples time.
1. Plug in all cables and adapters
2. insert a valid programmed key into the IGN and turn to run position.
3. start AE software and connect to vehicle if not set to automatically do so.
4. at the vehicle selection menu change "Enhanced Powertrain" to " Passive Anti-Theft"
5. click ok
6. click "Current" to view codes, Verify there are not any PATS codes displayed.
IF the system shows ANY PATS code, Click clear and click the blue refresh button at top.
and then click current again to check code is cleared
7. Click " Onboard Systems " Tab
8. Change " Self test " to " PATS key programming"
* Steps 9-11 must be done rapidly, If not an error message will be displayed, Start at 9 again *
9. Click " Initate "
10. Use arrow buttons ( not arrow keys ) to select your option.
Erase and Program keys - DO NOT use this unless you have 2 PATS keys cut for your
Vehicle, It will delete all keys from memory and you will need 2 keys to start it again
On Screen instructions will guide you thru this process after the timer cycle is complete.
Disable Key Programming - Disables the option to add keys by cycling 2 valid keys.
Enable Key Programming - Enables the option to add keys by cycling 2 valid keys.
Program Spare Key - Programs addition key without having 2 valid keys.
11. Turn IGN OFF and click " DONE "
12. The 10 min timer will begin
If programming a Spare key, Insert key into IGN - do NOT turn.
13. The results or instructions for the option you chose ( step 10 ) will be displayed.
If you chose " Program spare key " an error message will be displayed " Key not programmed - System refusal or error" .
Turn on the IGN with the NEW Key
Click the Right arrow to select " Program Additional Key "
Click Done.
" Key has been Programmed " Will be displayed
Click " Exit "
" PATS security closed " will be displayed
Turn IGN to Off and remove Key
Wait 1 minute and Test all keys
If the vehicle starts and dies, Turn to RUN position for 1 min, Turn off and remove key, Wait 1 minute and re-test.
  #28
Old 05-22-2012, 08:44 AM
Tried it; doesn't work. When done with ign off my timer never stops after the 10 minutes. The timer just ran even up too 20 minutes.
  #29
Old 05-22-2012, 09:14 AM
Turn ign off, click done almost at same time..
  #30
Old 05-22-2012, 09:20 AM
I did 3 times, I deleted all keys, added 2 as required then added another key by using only 1 key as if I had lost 1 of the 2 keys programmed previously ... If you still have trouble, I'll video record it and send you link to YouTube. Then you can watch , pause and do it as I do.., let me know Scott
PATS key (specific tech info, need good service tech help) RV Tow'n Truck 1999 to 2016 Super Duty 3 10-28-2016 09:08 PM
Programming a spare PATS key Icefan71 1997 - 2003 F150 9 02-18-2016 05:35 PM
New key with PATS programming Skauber 1997-2006 Expedition & Navigator 1 11-12-2015 05:14 AM
PATS Thread - Program Your Own Keys & Other Useful PATS Info Tylus 2004 - 2008 F150 61 09-09-2015 07:35 AM
PATS and a lost key ssharber 6.4L Power Stroke Diesel 5 06-25-2015 06:11 PM
Tags
2002, auto, autoenginuity, enginuity, escape, ford, issue, key, oem, parts, pats, program, reprogram, tsbs, wheres
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
