*TV MOUNT FOR RV* - Ford Truck Enthusiasts Forums
*TV MOUNT FOR RV*
Old 08-27-2011, 11:37 AM
BPofMD's Avatar
BPofMD BPofMD is online now
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
*TV MOUNT FOR RV*
Am looking for a flat screen mount for a 24-32" flat screen that I can install in my 07 Arctic Fox. It wasn't built for a flat screen, it has a space for a 25" CRT TV just inside the door. Don't have any wall area I can use but am trying to find a articulated mount I can screw to the wall above the counter where the CRT goes.
My question is, will an articulated mount take the bouncing of a traveling flat screen (24-32") when it is folded back?
Or, does anyone else have any ideas? Can't use a regular wall mount as the need to have a the clearance to bring the TV out a bit from the window. Maybe a cabinet mount? There is a cabinet above the area where the CRT sits. Again, will those mounts take the bounce of the RV moving?
Thanks for any replies!
Old 08-27-2011, 11:41 AM
ToMang07's Avatar
ToMang07 ToMang07 is offline
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
Old 08-27-2011, 11:47 AM
Robert6401's Avatar
Robert6401 Robert6401 is online now
Robert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to all
I would probably try to find out what the RV manufacturers use. There is a flat screen mounted on the wall of my rear bunkhouse, and it is on there very securely. I don't think I would trust one of those articulated mounts unless it was made to handle the abuse of riding in a towed vehicle, and even then I would be skeptical.
Old 08-27-2011, 12:44 PM
BPofMD's Avatar
Posting Legend
If not using the articulated mount is discouraged, I COULD remove the RV before we move and store in between the bed covers.......or use the cabinet mount....
Old 08-27-2011, 02:52 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
both of my flat panels are hard mounted on the walls so they don't move.
I have seen some that are mounted on a pedstal and then when unlocked can spin around.
Maybe that would be the answer. Take a look at some of the RV's and 5er's that have the tv that spins around from the bedroom to the main living area and maybe that could be used.
Old 08-27-2011, 04:42 PM
RV_Tech's Avatar
RV_Tech RV_Tech is online now
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
I used an articulate mount for several years in one of our motor homes without a problem with a 22" set. I just made sure to collapse it all the way back when traveling. I have also used one and just took the TV off when we went down the road in our travel trailer. It is pretty easy to slip the TV off the mount.
Steve
Old 08-27-2011, 06:01 PM
BPofMD's Avatar
Posting Legend
I just may do that...a 24-32" flat screen doesn't weigh anywhere NEAR that of a 25" CRT!!!!
Old 08-27-2011, 07:41 PM
rattleNsmoke's Avatar
rattleNsmoke rattleNsmoke is offline
rattleNsmoke is gaining momentum as a positive member of FTE.
There are several manufacturers that use arms that pull out and swivel. I saw one that pulled wayyy out and pivoted almost 180 degrees and could be viewed outside thru the screen door!
Old 08-28-2011, 06:52 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.mistakenID is gaining momentum as a positive member of FTE.
I got my articulated mount at Sams Club. Heavy duty mount, no problems at all with vibration. It also tilts up and down something like 20 degrees, -5 to +15. $50 which isn't bad from other prices I've seen.
Found a link, OmniBasics Full Motion Mount for 19" - 47" TVs - Sam's Club
Old 08-28-2011, 07:13 AM
c125bob's Avatar
c125bob c125bob is offline
Buy American
c125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputation
I use an articulated mount but wouldn't move the camper without taking the TV off the mount. I wrap it in a small blanket and secure it under the bed. I bought 2 of them and rigged up one to work outside under the awning. I installed the mount in a storage locker, connected cable to the camper system, open the door, swing out the mount, drop the TV into it and kick back. So far no issues.
Old 08-28-2011, 09:20 AM
perryg114 perryg114 is offline
perryg114 is gaining momentum as a positive member of FTE.
Here is a place that might have something that will work for you. You can do some searches yourself because my search may not have gotten all of them.
Search results for articulated TV mounts
Perry
Old 08-29-2011, 04:42 PM
BPofMD's Avatar
Posting Legend
If I need to remove the TV from ANY mount for moving, I'll stick to NO mount at all and use just the foot mount that comes with the TV......and save myself up to 100 bucks.....
Old 08-29-2011, 04:53 PM
RV_Tech's Avatar
Quote:
The industry uses these things all over the place and there is one manufacturer that specializes in them. I don't think there is much of a problem. All I ever did with mine was push it back to the wall and tightened it so it stayed in place.
Of course, just using the foot is simple enough and cheaper.
Steve
Old 08-29-2011, 07:38 PM
c125bob's Avatar
Buy American
It may be OK to run with the TV in the mount. I just don't want to chance it, there are lot of things that can go wrong and only one thing that can go right ! Simple and easy to slide it in and out and it saves counter space for me. It's a personal preference I guess.
Old 08-29-2011, 07:44 PM
RV_Tech's Avatar
Quote:
I agree. Everone does things differently. I haven't heard of any problems, but who knows?
Steve
Smart T.V. hook up daveengelson General NON-Automotive Conversation 4 11-19-2014 03:05 PM
Do you leave the TV(s) in your RV Irelands child Fifth Wheel & Gooseneck RV Towing 14 11-17-2014 10:04 AM
22" LED TV install w/ Inverter/Entertainment Mods Sian_Sam Excursion - King of SUVs 24 09-24-2013 09:11 PM
CRT HEI Install 72Truckin 1967 - 1972 F-100 & Larger F-Series Trucks 30 03-12-2013 11:50 PM
I'm beginning to write in a limited way at RVLIFE.COM Greywolf Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 10 09-15-2008 09:10 PM
Tags
2011, bed, camper, curtq20, f250, install, large, lid, mount, mounting, mounts, rv, truck, tv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
