RV Tank vent question
I removed my RV fridge to install a residential unit, and I noticed behind the fridge there was a vent pipe coming out of the floor and going almost to the ceiling, but not thru it. It has an open end with no cap.
Just wondering what its for
I alway though the vents went tru the roof to the outside.
Its a 2003 cedar Creek 36 rlts 5'r
Steve
Not sure there is anything to be gained by making modifications. What is the problem the way it is?
It is venting through the roof. I can't find anything in the code that makes this system a violation and it actually is code legal to vent through the sidewall orthe roof. The code refers to a venting system and the system has to vent to the exterior.
Steve
Steve
Steve
Steve
However, what you said makes sense Steve, it was a sealed area before.
I guess I'll add another weekend project to my list and vent it out thru the roof.
Thanks guys.
Well the new fridge does not seal around the edges like the Dometic did, plus I blocked off the original fridge wall vent, but left the roof vent operational. From time to time I get a smell in the camper, and Its coming from that area. I just couldnt believe they would vent something into the camper like that, and it dosen't go thru the roof.
Thanks guys.
Thanks guys.
Even though you run this vent on through the roof, the new fridge should still be sealed air tight from the interior of you camper. It is a carbon monoxide risk unless it is, if the furnace happens to be mounted directly under the fridge as it often the case. I have had a couple where the wind would blow the furnace exhaust back in through the old refrigerator vent in the winter. Otherwise it is not an issue.
I didn't catch in the original post the new fridge is a residentail model! Still learning to read, I now understand why the chase behind the fridge is not air tight.
Steve
My furnace is under the fridge, but it is sealed in a box of its own.
I've seen where the furnace is visable when the fridge is removed, but not on this camper. I didnt even have to bulid a shelf for the new residential fridge to sit on, There was already one there.
I certainly appreciate the heads up on the carbon monoxide, I'll take another look back there before i use the furnace.
Between the fireplace, the heat strip, and my Eden pure, I should be nice and warm without using the furnace.
I suspect further examination will find a grey are tank located beneath, but again with RVs anything goes.
Steve
