Brakes - calipers and rotors need some input
I'd add a good hardware kit if the caliper is bare...you may also want to get the caliper mounting pins/sleeves/bolts, too. The old ones may be serviceable but many don't want to put the time into cleaning & inspecting the old ones.
May also consider renewing both front hoses...I haven't seen ANY front brake hose last more than 125K miles in the past decade.
I agree about the slide pins and hoses. If your calipers are working and not leaking or dragging I wouldn't replace them though. Just gravity bleed them till you have clear fluid coming out and clear fluid in the master. That is very important to do every couple years. They will last forever if you do that. water and rust inside is what kills them. And broke off bleeders. That's why I replaced mine last time. My kid loosened them the wrong way!
you can re-use your studs, but doesn't hurt to buy new ones.
Get a nut or something and put it on the end of the stud and beat them out with a hammer.
To put the outer to the rotor, use an impact wrench and a washer and a junk lug nut to suck them up into the assembly.
Pretty easy, just a PITA.
done. yeah the left side was an all day job. having to go back and forth from the puter to the fridge to the barn to the puter to the fridge to the barn. not to mention a trip to 3 different parts stores for a ridiculusly large socket. the right side took an hour and a half. since I knew how to do it and i already had the 2-3/4" bearing retainer nut socket. discovered it has a fuel leak. its been parked in the barn while i found time and money for parts and this morning theres a large puddle on the floor so I get to investigate that tomorrow. thanks for all your help.
