Looking for a rear lower shock mount - Ford Truck Enthusiasts Forums
Old 08-27-2011, 09:04 AM
mkrog mkrog is offline
mkrog is starting off with a positive reputation.
I am in need of a lower shock mount,rear right side. for a 57 F100.does any body sell them? I have checked all my catalogs and can't find any body that has them.If any body know were I can get one please let me know.None of the bone yards around here has any thing that old
Thanks
Old 08-27-2011, 09:06 AM
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.
pm sent....Bill
Old 08-27-2011, 04:24 PM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is online now
bigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud of
Krog,
If your 57 has the 9" rear end you must use a shock mount from a 57-60, unless you just need the shock mount stud.
The lower spring perches/shock brackets are different from the 53-56's compared to the 57-60's
The dana 44's tube was smaller in diameter than the 9" tube and the brackets are specific for each rear end.
I know clear as mud!
Old 08-27-2011, 09:46 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Quote:
Originally Posted by bigwin56f100 View Post
Krog,
Is there a left and right with these things. I can't remember without going out and crawling under. I think I have one kicking around somewhere.
Old 08-28-2011, 01:58 AM
Quote:
Yes there is.
Old 08-28-2011, 05:59 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
B6C-18193-A .. Lower Shock Absorber Mounting Stud-to Spring Seat Cap / Stud: Right/Left is the same / Obsolete
Applications: 1956/58 F100/250 / 1959/60 F100/250 2WD & 4WD // 1956/77 P350 (P Series Parcel Delivery).
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
GRIESEL MOTOR CO. in Okarche OK has 5 = 405-263-7242.
All 1957/58 F100's have 9" rear axles, as do 1959/60 F100's without Limited Slip.
1959/60 F100: If Limited Slip was ordered, Ford installed Dana 44 rear axles.
Ditto 1961/67 F100's and some 1968 F100's. 9" with Limited Slip was not offered for F100's until mid-year 1968.
9" rear axle introduced in 1957, Limited Slip in 1959 (for F100/250's & FoMoCo Passenger Cars w/a 9").
Old 08-28-2011, 09:58 AM
Is that the mounting bracket or just the stud ?
Old 08-28-2011, 10:14 AM
Ford Truck Parts Catalog part number and description: B6C-18193-A Lower Shock Absorber Mounting STUD -to Spring Seat Cap / Right/Left is the same.
You asked for a lower right shock mount, but didn't specify which parts you needed. Since the stud could be stripped or had crystalized and snapped, that's all I listed.
Old 08-29-2011, 09:18 AM
Sorry but thats what the Ford Service Manual calls it.
Old 08-29-2011, 10:54 PM
gearhead1952's Avatar
gearhead1952 gearhead1952 is offline
gearhead1952 is gaining momentum as a positive member of FTE.
I have this set for sale pm if interested. I won't break up the set and sell just the one part tho.
Old 08-29-2011, 11:22 PM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
If mkrog is not interested, I'd like to have a shot at them. I'm in need of a set. PM sent, Thanks.
Old 08-30-2011, 12:13 AM
Quote:
Thank you but that not the right ones,looks like off a 56 or earlier
Old 08-30-2011, 12:26 AM
I personally pulled these off a 1960 F100.
Old 08-30-2011, 02:05 AM
Dano78's Avatar
These should look and mount just like the '53-'56 ones just with the wider 3" spacing for the 9" rear. Correct me if I'm wrong??
Old 08-30-2011, 04:44 AM
1957/58 F100:
According to the '57/63 Ford truck parts catalog pic, the rear shock has an upper threaded end that fits to the frame bracket, an eye on the other end.
The stud (B6C-18193-A) passes thru the eye, connects to a L shaped bracket (B7C-18132-A ~ R/S = 1957/58 only) that has two mounting holes.
This bracket then mounts below the lower spring cap. The rearmost spring clip (U-bolt) passes thru the lower spring cap, then thru the two holes in the bracket.
The stud is the same as '56, but on '56's, the stud attaches directly to the lower spring cap. 1957/58 is different, uses the bracket which is R/L specific.
B6C-18193-A .. Lower Shock Absorber Mounting Stud / 1957/58-to bracket (to spring cap on '56's) / Obsolete
B7C-18132-A .. Right Lower Shock Absorber Mounting Bracket / Obsolete
BOWMAN SALES & SERVICE in Bowman ND has 1 = 701-523-3257.
No other Ford Dealer, no obsolete parts vendor has any.
04' rear upper shock mounts nmlongbow 1999 to 2016 Super Duty 0 08-04-2016 04:21 PM
'55 F100 Rear Lower Shock Mount Just 5 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-14-2014 03:01 PM
78 F250 Is there a bolt on rear lower shock mount? Buckhorn2 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-12-2014 04:58 AM
shock mount TWODOGS522001 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 12-04-2012 09:34 PM
rear shock perch spun billcollector 1999 - 2003 7.3L Power Stroke Diesel 14 09-16-2012 06:14 PM
Tags
1957, 1959, 1996, axle, bottom, f1, f100, f350, ford, lower, mount, mounts, pseries, rear, shock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
