F750 with Allison Tranny trouble code - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 08-27-2011, 06:25 AM
buba 11 buba 11 is offline
buba 11 is starting off with a positive reputation.
Hey All,
I got a 2008 F750 with the Cummins, Allison 6speed powertrain combination.
The Allison shift panel comes up with a trouble code something about torque convert er lockup selenoid circuit low, They say it may be a wire broken or chafing wire somewhere. The Allison people want to replace the computer and valve body on the transmission which will break the bank!
The tranny has not engine breaking and the torque converter does not lock up and the Jake brake does not work.
Has any one run into this problem, what was the cure?
Thanks for replies,
Bubu 11
Old 08-30-2011, 08:08 PM
2rangers 2rangers is offline
2rangers is starting off with a positive reputation.
could be internal harness or external harness could be solenoid very rarely do i ever replace tcm or valvebody need tranny model and code to do more research
Old 09-02-2011, 04:13 PM
Allison Dealer fixed it
Long and short of it, the wireing harness was rubbing against the transmission, 3 wires shorted out. Dealer lengthened the wires and repaired the harness. Shifts good now!
I was charged 250.00.
Old 09-02-2011, 04:26 PM
nevrenufhp's Avatar
nevrenufhp nevrenufhp is offline
nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.
Sometimes its well worth it!
Old 09-03-2011, 11:15 AM
external harness was my first guess in the 10 years i have been working on allisons i have never replaced a whole valvebody and only a few tcm s with a solenoid code
Determining the Right Allison Automatic. . . FordMan1981 Clutch, Transmission, Differential, Axle & Transfer Case 1 02-22-2017 08:22 PM
Allison MT650 interchange needed Steve Noland Large Truck 2 04-24-2015 10:33 PM
F650 chip Hiredgun welding Computer Chips & Tuners 2 12-28-2012 07:22 AM
does allison make torqshift? scup27ri 1999 to 2016 Super Duty 9 12-21-2010 08:52 PM
Allison AT545 with a 7.3 IDI? RPM1975 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 10-22-2009 12:48 AM
Tags
1972, 2000, 2007, 2010, allison, codes, f750, ford, md, problems, read, trannies, tranny, transmission, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
