MY 93 F150 5.0 keeps jumping time! Help!!!
It is now Sunday. This is what I have done. I removed the distributor, removed the roll pin holding on the gear. It was fine, reinstalled new pin. Set to TDC and re-installed distributor. Replaced dist cap, checked wires for tightness and firing order. Started engine and let it warm up, removed SPOUT connector, set timing. Same old problem. After a short test drive up and down the street, it wouldn't idle in drive or reverse. Checked timing. It was off again.
Could the cam have bad teeth or would that show up in some damage to the distributor gear? There were no metal shavings on the gear, although they may have been cleared away by oil.
I'm at my wits end. Please, if anyone has any thoughts, I could use some help!
What I would do is set the timing about 45 degrees before TDC remove #1 plug, use a long small screw driver and touch the top of the piston. I have a long gas welding rod threaded that I use on my dial indicator and magnetic base. Gently turn the motor, you can do it your self I just did one. Feel when the piston is at TDC or just over and look at the timing mark if it is not on the mark, or just past, you lost the key when you installed the gear on the crank, or it could have sheared, you have to hold the ring gear to torque the dampener bolt.
Just a thought!
Just a thought!
I really didn't want to go back into the timing chain area again, unless I really had to. However, if I do and there is looseness or some problem not related to the tightness of the bolts, what could be the cause? I've probably replaced a dozen timing chains in the past 40+ years and have never had to worry about it afterward. It's not like I'm a newbie, I usually align and tighten, and re-check at least twice before I replace the cover.
Just a thought!
Just a thought!
Well, I solved one of my problems!
It seems that my old timing light was the culprit in the timing marks on the balancer moving around. Now, I'm going to check the spark plug wires firing order and see if that helps.
FYI, the sensor that clips to the plug wire from the timing light was bad, resulting in inaccurate timing info. If it hadn't stopped working, I would NEVER have thought of this! I called a friend with a newer digital timing light and the timing seems to stay put.
After checking the plug wires, we'll see how it does on the road test.
Wish me luck!!!!
Wish me luck!!!!
Wish me luck!!!!
Wish me luck!!!!
Eureka!!!
Who woulda thunk it????
The bad sensor in the timing light was the cause of my problem (I wonder how I can blame my hair loss on it, too?). If anyone ever experiences this type of phenomenon, try another (preferably, newer) timing light. It'll save you time, stress, hair loss (got it in! ) and possibly ulcers!
I want to personally thank each and everyone of you fine people for sharing your expertise in this matter and allowing an old man vent his frustrations. I really appreciate your help! Thank you all!
#28
Eureka!!!
Throw the boys a rep point, and do hang around, even though you are good for now.
#29
#30
