Missouri Chapter Join Chapter , Leader:77&79F250
Bumper lift for a body lift.
Old 06-05-2011, 06:07 PM
earthquake68's Avatar
earthquake68
earthquake68 is offline
If you raised the body off the frame, the bumper no longer sits in the correct place. With a 3" body lift, the bumper sits below the grill shell instead of over the bottom lip where it belongs. Follow along as we correct this problem.
Here are the stock frame horns with the body lift already installed....
First we scribe a cut line using a square so the cuts are perpendicular to the ground and we slide the bumper straight up.
Being careful to stay on the line, cut them suckers off.
Now measure 3" and slide the pieces you cut off up and then clamp them in place and check the measurement again.
Do both sides, then tack everything in place and set the bumper to make sure it looks level with the truck.
Even welded on both sides, this isn't very strong. You need a kicker in there to prevent twist. Here I have two pieces of 3/8"x2" flat stock cut and shaped to fill the void.
After welding it in place....
The whole reason for this kicker is to give it extra rigidity, so weld it everywhere you can, front and back. This sucker isn't going anywhere.
Old 06-05-2011, 07:11 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,279 Likes on 2,437 Posts
Did you get the measurements/scribe line off your new frame by chance? Looks good there Alan, nice job on the mod and thread.
Old 06-05-2011, 07:21 PM
earthquake68
No, I just picked a spot on the frame that looked good. I think I went 2 1/2 or 3" back.
Old 06-05-2011, 07:28 PM
77&79F250's Avatar
77&79F250
You know I am thinking that's a great time to add a front receiver hitch/frame horn brace. Maybe out of a old rear hitch and tie it in with those kicker plates?
Old 06-05-2011, 08:01 PM
pintoches's Avatar
pintoches
pintoches is offline
That looks cool Alan! Bob wheres the after pics?
Wish I could weld like that!
Old 06-05-2011, 09:04 PM
whiskey runner's Avatar
whiskey runner
whiskey runner is offline
looks good alan...every little bit helps ole ka'bluey...
Old 06-06-2011, 07:25 AM
earthquake68
I told Bob I would be there all day with the yard sale. When he pulled up I was snoozing in one of the lounge chairs I had "on display". Those stacks woke me up. ...Darn noisy trucks!
Old 06-06-2011, 09:41 AM
ubereal2's Avatar
ubereal2
ubereal2 is offline
Snoozing... You were passed out! Thanks again, nice job
Here is a couple after pics.
Unk Bob
Old 06-06-2011, 10:35 AM
77&79F250's Avatar
77&79F250
Looking good there Unk Bob, whats next?
Old 06-09-2011, 09:56 PM
zstangkrewson's Avatar
zstangkrewson
zstangkrewson is offline
dont get me wrong, it looks good, but if you hit something, your going to get alot of damage..... i do belive there are brackets that will relocate a front bumper on a body lift... i could be wrong..
Old 06-09-2011, 10:10 PM
77&79F250's Avatar
77&79F250
You are right, but you have to notch the bottom of the bumper for it to look right.
Old 06-09-2011, 10:27 PM
earthquake68
If more strength is that important to you, you could always add a triangle brace on top of the frame rail. Then it would be stronger than factory with all the triangulation and bracing in the front.
Old 06-09-2011, 11:10 PM
ubereal2's Avatar
ubereal2
ubereal2 is offline
Hit Something...... THAT's why I have cheap insurance... And a good attorney!
Old 06-10-2011, 10:22 AM
cyclopsblown34's Avatar
cyclopsblown34
cyclopsblown34 is offline
Alan, you look to do real good work short circuiting metal together.
Old 06-10-2011, 05:29 PM
earthquake68
Thanks Chip, I do my best.
Quick Reply: Bumper lift for a body lift.
