Going to tackle water pumps today (1952 8rt F1) - Page 2 - Ford Truck Enthusiasts Forums
Old 08-26-2011, 08:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Quote:
Originally Posted by FlatHeadFat View Post
I just looked at the mounts I ordered and the package says 6cylinder! So angrily, I traced the part numbers back and online they are labeled under v8. They look roughly the same size as the old mounts.
Product number 8L-6038-B
The Parts CD omits much of the info about 52 flat-V8 motor mount parts but what I found was:
Bolt - 1/2"-20 x 3.40" long (note that '48 - '51 is a 7/16")
Upper insulator (rubber) - 8L-6038-B
It does say that for '52, 6-cyl and all V8's use the same parts. Seems like you're good!
Old 08-27-2011, 04:29 AM
FlatHeadFat's Avatar
FlatHeadFat FlatHeadFat is offline
FlatHeadFat is starting off with a positive reputation.
I hope so. If they are too large, what kind of problems should i be looking for?
Gooch's Radiator/Engine Backflush Procedure and Coolant Information Stewart_H 1999 - 2003 7.3L Power Stroke Diesel 306 11-29-2016 04:21 PM
My experiences with Gooch's coolant flush procedure AMG-SM 1999 - 2003 7.3L Power Stroke Diesel 28 05-09-2015 01:55 PM
Coolant Flush Macs1964F100 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 06-04-2014 10:29 PM
GUIDE: How to remove the Water Pump in a 1990-1997 4.0L OHV V6 Ford Aerostar Lee Binder Aerostar 5 02-19-2014 03:28 PM
coolant/heater hose routing tgore3 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 09-01-2006 03:36 PM
Tags
1951, 1952, 226cui, 8rt, f1, flathead, ford, pump, pumps, spec, truck, v8, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
