one wire alt. on flat head v8 - Ford Truck Enthusiasts Forums
Old 08-25-2011, 10:18 PM
r2000f150 r2000f150 is offline
r2000f150 is starting off with a positive reputation.
will the one wire alt. do ok in my 1950 f3 with flat head v8, thanks in advance
Old 08-26-2011, 04:42 AM
1949f1's Avatar
1949f1 1949f1 is offline
1949f1 is gaining momentum as a positive member of FTE.1949f1 is gaining momentum as a positive member of FTE.
yes, the one wire is the way to go.
Old 08-26-2011, 06:00 AM
FlatHeadFat's Avatar
FlatHeadFat FlatHeadFat is offline
FlatHeadFat is starting off with a positive reputation.
How does one go about converting an original 3-wire generator to a single wire alternator? I've been contemplating the switch, and my impatience and lack of spending cash wants me to go with the 6 volt.
Old 08-26-2011, 10:18 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Quote:
There are a few places that sell 6v/pos. ground alternators. Since they use a custom internal regulator, this is something you have to buy ready-to-go. 1-wire or 3-wire, whatever they sell is what you get. No big deal either way, they are a huge improvement over a generator IMO.
There are some issues getting one that lines up with the truck WPs. See here for instance:
http://www.ford-trucks.com/forums/92...belt-help.html
Old 08-26-2011, 11:51 AM
1949f1's Avatar
i had that trouble when i put one on the 239 flat head. i just cut the mounting ear on the long part of the alt. just enough to line up with the pully. it line up perfect and had no trouble.
Duel Alt's not charging. Rogue427 6.0L Power Stroke Diesel 11 07-02-2013 05:34 PM
converting to internal regulator on alt. F-250 restorer 1973 - 1979 F-100 & Larger F-Series Trucks 20 08-13-2010 10:54 PM
altenator issue megalomania 6.0L Power Stroke Diesel 18 09-27-2009 11:53 AM
1G alt wiring to a 2G alt xlt guy Electrical Systems/Wiring 6 06-17-2007 08:48 PM
1949 Engine Paint FORD PARTS GUY 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-15-2004 07:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
