6f35 transmission help - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 08-25-2011, 05:41 PM
ibecleaningup1 ibecleaningup1 is offline
ibecleaningup1 is starting off with a positive reputation.
Hello,
My wife has a Ford Escape with a 6 speed auto (6f35) trans that is giving us problems. I am looking for a diagram of the transmission or just of the solenoid and linkage side. The reason is we took it into the Ford dealer to have it looked at because it would jump out of gear sometimes while driving. They said it was a solenoid but they would have to replace all of the solenoids at the same time. I understand that but now they say it will not go into gear as it should and I have to replace the transmission. It is just out of warranty so the cost will be $4200. It drove when I took it into their shop but now will not so I cant help but think it is something small and I want to work on it myself.
Sorry for the long story but if anyone has access to the diagram I would appreciate it.
Thanks, James
Old 08-27-2011, 08:11 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
I don't have access, but you can get most transmission manuals from:
ATSG Home Page
Every manual I've gotten from them has been a duplicate of the factory manual.
I think I would be having a pleasant discussion with the service manager. They seem to have successfully broken your transmission while they were attempting repair. If you drove it in, it must have worked, no? If it doesn't drive now, they did *something*.
If nothing else, ask to speak to the zone rep and explain the situation. You could also check with independent repair shops. If you poke around, you might find out about the class action suit for owners of your transmission. I know nothing about it except that I read that it exists.
I would NOT be spending money at the place where your truck is at this time. I read the solenoids can be replaced after removing the valve body, but that should not require a new transmission. If you went out of gear, you likely lost pressure. There is an 'epc' solenoid that modulates the apply pressure in the transmission. If it went, I guess it could make the pressure so low that everything slipped and you went no where.
Did the fluid smell burned and have a very dark color? You may have had slippage for some time before it became obnoxious ... causing unknown damage to the frictions and steels.
tom
2002 f350 cold starting problems chaoticghost 1999 - 2003 7.3L Power Stroke Diesel 23 03-15-2017 05:23 PM
Need help with a p0756 code Disnynuts 1999 to 2016 Super Duty 0 11-29-2013 01:17 PM
EBPV solenoid oil leak Help please! wycowboy 1994.5 - 1997 7.3L Power Stroke Diesel 3 04-12-2013 08:23 AM
Need Help. Lot's of codes for TCC, O2 sensor heater circuits, evap solenoids terrysumner 1999 to 2016 Super Duty 3 01-19-2011 09:21 AM
Direct drive upshift solution...for modded trucks SpartanDieselTech 6.0L Power Stroke Diesel 11 09-25-2005 12:25 AM
Tags
2011, 6f35, buy, diagram, escape, ford, problem, problems, reading, recall, recalls, replacement, service, tag, transmission, tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
