1948-50 vin - Ford Truck Enthusiasts Forums
1948-50 vin
Old 08-25-2011, 06:38 PM
markuth markuth is offline
markuth is starting off with a positive reputation.
1948-50 vin
My vin last 6 are 454539. Is this a 49 or a 50?
Old 08-25-2011, 07:56 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Assuming the first two numbers are 97 or 98, it's probably a '50. I seem to recall our 49-50 historians mentioning the changeover occured near the 300,000 mark. Do you have numbers stamped on your firewall? In that string should be a date code. See if you can find that. Post any numbers you find here.
Old 08-25-2011, 08:37 PM
vin 48-50
Hi there!
Thanks for your reply.
the rest of the vin is 98RC454539.
The same # appears on in both places on the truck.
Regards,
Mark
Old 08-25-2011, 10:40 PM
52 Merc's Avatar
Which both places are you talking about? Your vin should be stamped on the right side frame rail, on a tag riveted to the firewall, and on a tag located on the inside of the glove box door. The numbers I was referring to are actually stamped into the sheet metal of the upper center of the firewall itself, near the cowl seam, not on a tag.
Old 08-26-2011, 08:33 AM
harleymsn's Avatar
harleymsn harleymsn is offline
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
Quote:
Unless it was built in Norfolk, Va, in which case it will be all the way over on the driver's side.
Old 08-26-2011, 04:16 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
the build code has been reported anywhere on the firewall - left, right, above the seam and below it. some don't have a stamping at all.
Gotta love Ford's consistency..... grin
How long to get a Vin# mrz50 6.7L Power Stroke Diesel 10 02-14-2012 10:54 PM
48-50 Ford frame? 48panel 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 10-05-2006 07:01 PM
Vin Number Nomenclature? 50th ann General Automotive Discussion 9 04-01-2006 12:26 AM
50, F-1 vin locations sturman3 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 04-10-2005 09:45 PM
1950 Vin# jpp 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 03-17-2004 11:28 AM
Tags
194850, ford, numbers, pickup, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
