Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-25-2011, 05:09 PM
mudder460's Avatar
mudder460 mudder460 is offline
Garage is empty, add now
mudder460 is gaining momentum as a positive member of FTE.
08 Expy a/c stops working from time to time
From time to time when we start the Expy up the a/c will blow hot air like the heat is on. We then have to shut the truck off and start it back up again to get it to blow cold air. Any ideas wheat might be causing this?
__________________
Andy
2008 Expedition Eddie Bauer
Arkansas Chapter Member
  #2 (permalink)
Old 09-09-2011, 02:32 PM
cstanley44's Avatar
cstanley44 cstanley44 is offline
2008 Ford Expedition
cstanley44 is gaining momentum as a positive member of FTE.
I had a 96 Explorer that did that too...
My solution was to turn the temp **** to hot then cold a few times, and it would then get cold
I thought it could be a vacuum leak in the heater controls
  #3 (permalink)
Old 09-09-2011, 03:33 PM
Jay Jay is offline
Jay is starting off with a positive reputation.
Mine just stops working from time to time. Shut the engine off for a while and it starts working again on start up. Also, While driving it will blow a momentary blast of air.
  #4 (permalink)
Old 10-25-2011, 03:32 PM
mudder460's Avatar
Ok, the truck did it again and I was home to check it out. The driverside air is blowing out HOT air, but yet the passenger side is blowing out the COLD air like normal. I wouldn't even know where to start looking to fix this. It doesn't do it all the time so by the time we would ge it to a dealer it would be working fine. Any suggestions?
__________________
Andy
  #5 (permalink)
Old 10-25-2011, 04:30 PM
cstanley44's Avatar
Do you have manual climate control or dual - diff temp each side?
If manual, I cannot offer an explanation.
If dual, seems the blend door for the drivers side is not working all the time.
The blend door is responsible for making the temperature you select by blending heat and AC. If its closed or not working on either side you get the symptoms you're experiencing
  #6 (permalink)
Old 10-25-2011, 08:00 PM
07nav 07nav is offline
07nav is starting off with a positive reputation.
I had the same problem with my MB R350 last year during the winter months. Changing the blower motor, did the trick for me!
  #7 (permalink)
Old 10-25-2011, 09:14 PM
mudder460's Avatar
I have the dual climate in the truck. I read a TSB about the F series for this problem but I didn't read about it including the Expy. Do you think this will cost me or be covered under the TSB?
__________________
Andy
  #8 (permalink)
Old 10-25-2011, 09:48 PM
cstanley44's Avatar
Dashes are a little different in the F150 vs the Expedition.
I dont find much on replacing one in a full size ford, but here's a nice write up for an Explorer that should give you an idea of what you could be in for.
I dont think its a terribly expensive part, but labor is the killer
How To: Replace Blend Door Actuator in 3rd Gen Ex. - Ford Explorer Ranger Enthusiasts "Serious Explorations"®
Tags
2007, ac, air, blower, conditioner, expedition, f150, ford, quits, reasons, starts, stops, suddenly, truck, working, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
