2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Remote start with MyKey
Old 11-08-2013, 10:44 AM
kw5413's Avatar
kw5413
kw5413 is offline
Originally Posted by brianz250
To drcdac
The code site is on the first page of this thread.
Now for my question. Does anyone know if this info also applies to the 2013 Expeditions?
Thanks
And 2013 Navigators?
  #32
Old 11-09-2013, 01:16 PM
kw5413's Avatar
kw5413
kw5413 is offline
This worked perfect on my 2013 Navigator. Button is easy to find. Couple of minutes and done.
  #33
Old 07-09-2014, 01:41 PM
ljw70's Avatar
ljw70
ljw70 is offline
Frustrated
Found all of this info and tried it on my 2014 Expedition. It does not work. Has anyone else tried it on a 2014? I do have an erroneous low tire pressure warning present right now. Maybe that is the problem.
  #34
Old 07-09-2014, 02:40 PM
kw5413's Avatar
kw5413
kw5413 is offline
Due to Ford's efforts to get the 2015s out I do not believe there is much difference between the 2013 & 2014. I know there isn't with the Navigators.
It should work for yours. Watch the video again and retry is all I can suggest.
  #35
Old 07-09-2014, 03:00 PM
brianz250's Avatar
brianz250
brianz250 is offline
I believe you are correct. I'm going to try this on my 2013 Expedition this weekend. I'll report back when I'm done. Thanks
  #36
Old 07-09-2014, 09:41 PM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
Please do. I just bought my wife a 2013 Expy KR and was going to install the bi-directional remote start. If it turns out opening the door kills the engine and the door ajar entry delay can't be enabled I'll pass on the Ford unit and install an aftermarket one. I've got a 2011 F-250 with factory remote start that works as a remote start should. Can't think of any good reason why Ford would design a system that kills the engine when you open the door.
  #37
Old 07-10-2014, 12:49 PM
ljw70's Avatar
ljw70
ljw70 is offline
Question Update - 2014 Expedition
I got my 2014 Exp. serviced and the low pressure tire warning light reset. Tried the programming as per instructions: Foot on brake, key to on position, hold the button for 10 seconds -- No horn chirps. Any suggestions?
  #38
Old 08-13-2014, 09:33 AM
steveg_nh's Avatar
steveg_nh
steveg_nh is offline
I'm wondering the same thing. I have a 2014 Expy Limited. I want to disable the shut off when you open the door. I've found tons of instructions on doing it, but no confirmation you can do it on a 14. I read one post somewhere that said the 14s use a CAN network, and you can't do it. But I can't see them changing it in 14 only, vs 13 and 12, etc.
I did a test yesterday too. Sitting in the truck, I used the remote start. Just putting the key in the ignition shut the truck off. Didn't touch the brake or open the door. So does disabling the door opening, if we can, also fix the shut off with key insertion?
  #39
Old 08-13-2014, 08:44 PM
steveg_nh's Avatar
steveg_nh
I just did my 14 tonight. Worked like a charm. You have to press the button hard, and deep, into it's socket until it bottoms out. The first time, I thought I was pressing it all the way, and nothing. No beeps. The second time, I got a better grip, and it worked great. I actually just did it twice. Once, to shut off the door open/key insert power down. And then I decided to extend the runtime to 15 minutes from 10.
Works awesome now! But does this disable MYKEY? The setting is still in my Setup menu. I just want to be sure that if the remote start is configured as a MYKEY, that driving away with it having been started by the RS, that it doesn't enforce any limitations on the truck in any way. I want all MYKEY stuff disabled.
  #40
Old 08-16-2014, 11:36 AM
ewmoose's Avatar
ewmoose
ewmoose is offline
Hey guys my first post here, just bought my wife a 2014 KR 4x4 and I can't find this button, where is it on the 2014 Expy???? This feature is worthless as it sits. Thanks for the help.
  #41
Old 08-16-2014, 11:40 AM
kw5413's Avatar
kw5413
kw5413 is offline
Welcome to the site.
Watch the video in post # 32. It is pretty detailed.
There are virtually no changes from 2013 to 2014.
  #42
Old 08-16-2014, 11:57 AM
ewmoose's Avatar
ewmoose
ewmoose is offline
It's a good video, but this dang button does not exist in this car lol I have looked everywhere shy of tearing the dash out.
  #43
Old 08-16-2014, 12:27 PM
steveg_nh's Avatar
steveg_nh
I had to remove the lower steering trim and the trim plate that holds the power pedal height adjustment button. My remote start button was behind that pedal button taped up very well to the harness coming off the remote start. It was completely hidden when just viewing from underneath the dash looking up. I just did it this week. Now too you can use the "quick stop" feature of the remote start.
  #44
Old 08-26-2014, 02:33 PM
ljw70's Avatar
ljw70
ljw70 is offline
No worky 2014 Expedition
I found my button - this sequence of events does not work on my 2014 King Ranch Expedition. Hold button and brake, horn does not chirp or go into programming mode.
This is an absolute terrible feature
  #45
Old 08-26-2014, 02:39 PM
steveg_nh's Avatar
steveg_nh
You have the single button remote start right? I bet you either aren't pressing the button all the way, or are missing a step. Be very careful. Press and hold brake, turn key to on (do not let go of brake), press button firmly for about 10-12 seconds (make sure the button has bottomed out, meaning you really pressed it all the way and you are still holding brake), and then it should enter programming mode. You can then let go of brake and continue.
If it really isn't working, maybe you don't have the same system (which I find unlikely).
The first time I did it, I couldn't get it into programming mode. I wasn't pressing the button far enough in. Oh, make sure all doors and the hood are closed too. And all interior lights OFF.
Quick Reply: Remote start with MyKey
