Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-25-2011, 04:34 PM
makajack makajack is offline
Garage is empty, add now
makajack is starting off with a positive reputation.
Angry Airbag Light Stays On Steady
My truck has been in an accident where the front airbags were deployed. It has since been fixed but the airbag light on the dash will not go out. It doesn't flash to show a code as I've read in other forums, it's just on steadily. I've had the module, and front crash sensor replaced along with the airbags ofcourse and it still will not go out. The body shop I took it to hooked it up to the computer and it is displaying a sensor problem, but what sensor error could it be getting? Any and all pieces of helpful information are welcomed and will be appreciated. Thanks!
  #2 (permalink)
Old 08-26-2011, 10:38 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Did you repair this yourself? Airbag lights can be a sign the senors are bad or not connected correctly or another electrical problem. I would say dealer time.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 08-26-2011, 03:32 PM
Actually no Berry, I took it to a reputable body shop who was able to fix everything but that one problem with the airbag light. I've also read in another forum that a bad battery can be the cause of that as well, and he mentioned to me that the battery need to be replaced so that's on my to do list this weekend to see if that will work.
  #4 (permalink)
Old 08-26-2011, 04:51 PM
berry1234's Avatar
I wouldn't keep throwing parts at it, but thats my take. I have never heard of a bad battery starting the truck but causing the airbag light to go on.
__________________
  #5 (permalink)
Old 08-27-2011, 08:10 PM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
Check the SRS fuse in the SJB. The location should be listed in your owners book. I think it is a 10 amp, #32 position. If it is blown or missing the light will stay on. Ford recommends pulling the fuse to depower the system. The fuse may have been removed to replace the air bags and not reinstalled.
__________________
2013 Explorer Limited
87 Ranger, XLT
  #6 (permalink)
Old 08-28-2011, 09:47 PM
Slc, I checked the fuse but it was in place and still good so that's not it, but thanks for sharing that info. I also replaced the battery and still got the steady lit light. Not sure what next besides being clobbard by the dealer. I am still open for suggestions.
  #7 (permalink)
Old 08-29-2011, 09:24 AM
rgilbert rgilbert is offline
rgilbert is starting off with a positive reputation.
Found this link doing a Google search:
Airbag light On | Airbag Module Resets | Repair Your Airbag Light
Trying to diagnose and reset the airbag is dangerous. Please repost what you find and be careful.
  #8 (permalink)
Old 09-11-2011, 03:06 PM
shorebird's Avatar
shorebird shorebird is offline
Wage Slave
2008 Ford F-150
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Take the vehicle back to the repair shop.
They were paid to correct EVERYTHING.
Should you have another accident and the SRS not function properly someone could die.
A vehicle will not leave our shop until something like that is corrected.
We take the vehicle to the dealer and have them diagnose and correct it.
The liability to the repairer is immense.
When you start the vehicle the light will blink a code that will give the service people an idea of what to check for.
I had a repaired car that was blinking a 27 (2 blinks followed by 7 blinks repeated 3 times) then it set a steady light.
The 27 indicated a low resistance in the drivers airbag.
__________________
2001 E-350SD V10 Triton 3.73LS, ROTW 01/02/10
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb; '05 & '07 Taurus SEL's
Bryan L. Unique Collision Center Towing & Wreck Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
Tags
1997, 2003, 99, airbag, dashboard, eddie, expedition, f250, ford, fuse, light, lincoln, navigator, reset, stay, stays, steady, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
