ABS Rear Speed Sensor Malfunction (Replaced) - Ford Truck Enthusiasts Forums
Old 08-25-2011, 01:11 PM
ChrisCarter ChrisCarter is offline
ChrisCarter is starting off with a positive reputation.
I have an ABS light on. I have crawled under the truck I don't know how many times everything is connected just as it should be. The wires did have to taped up because they burnt into after getting against the exhaust at some point, but I had fixed that awhile ago, I've even tore back into the tape and re-did everything again, nothing gets rid of the ABS light. When this first happened it would go away after I turned the truck off, but would come back after using the brakes a few times, especially harder stops. Then it got to where it just came on and stayed on, and didn't go out no matter what. Thinking my ABS speed sensor went, I bought a brand new motorcraft one from rock auto it fits perfectly in the rear, plug looks good. I can't find NOTHING that would keep this light on. The code is always the same "Rear ABS Center Speed Sensor Input Malfunction" is there anyone who knows how to get rid of this?
Old 06-10-2014, 10:20 AM
slow96z slow96z is offline
slow96z is starting off with a positive reputation.
Hey Chris, I know it's been a while since your post, but do you remember what the resolution was? I have a friend who is experiencing the same thing (minus the burned wires) and a new sensor didn't fix it. Any help would be appreciated!
Will an ABS + code of front left speed sensor cause funny shifting (2001 F250) thegreatgate 1999 to 2016 Super Duty 3 06-10-2016 09:47 AM
ABS affecting Speedo and Shifting. Can you solve the riddle? cmdavies91 Brakes, Steering, Suspension, Tires, & Wheels 3 11-16-2015 10:53 AM
ABS Light - Code C1096 - Fix JustFixIt 1997-2006 Expedition & Navigator 3 08-05-2015 05:21 PM
abs code c1236 05F250DSL 1999 to 2016 Super Duty 0 03-29-2015 01:24 AM
ABS Trouble edsheridan Excursion - King of SUVs 1 08-25-2014 03:39 PM
Tags
08, 150, 2004, 2006, abs, f150, f250, ford, pick, rear, replace, sensor, sensors, speed, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
