Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-03-2003, 01:29 PM
WXboy's Avatar
WXboy WXboy is offline
WXboy is starting off with a positive reputation.
Question Will that common driveshaft problem destroy anything?
Guys and Girls,
You know how almost all Rangers have a problem with "slack" in the driveline, so that when you first take off you feel a jerk or bump? Many people have claimed that taking the driveshaft out and greasing the slip yoke will solve the problem. My question is, what if you never do anything about it? Will the problem get worse over time, or tear up anything? Many Ford dealers will tell you it's "normal" and elect not to fix it. So that's why I wonder if it's worth fixing or not.
Thanks.
__________________
2003 Ford Ranger S/C FX4
  #2 (permalink)
Old 04-03-2003, 02:54 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all
I had the driveshaft thump problem develop over a period of time. I'm one of those people who advocate taking off the driveshaft and greasing the slip yoke. I did it several months ago when my thump seemed to be getting worse, and the cleaning and greasing worked very well. Did not competely get rid of the problem, but a lot of improvement. I recently took the drivehsaft off again and cleaned it and regreased it, this time using teflon grease. And that has worked even better. Virtually no thump at all.
My understanding is that the thump is caused by the way that the Rangers are designed and the angle of the driveshaft. Supposedly, there are brief moments when the torque and angle of the shaft is such that the yoke is not free to "slip" as it should. It sticks for a bit and then when it's free to slip again, it slips quicker and with more force than it should. Now of course, this is all happening in millisenconds.
Many people report less or no thump when they have a bit of a load in the bed which affects the angle and torque of the shaft by lowering the rearend and increasing weight. Obviously, the slippier the yoke and splines are, the less chance there is for thump. I've even read where people had a one-piece driveshaft installed, removing the slip yoke altogether, as a remedy.
As for whether or not leaving the problem alone will harm your Ranger in the long run, I would keep in mind the rear seal in the transfer case. Much of the force of the thump is felt in the area where the driveshaft bolts to the transfer case, which is about 12' or so from the yoke itself. Just my opinion on that, though.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #3 (permalink)
Old 04-03-2003, 04:50 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE. Ken00 is gaining momentum as a positive member of FTE.
This is from the most resent TSB on the problem.
Replace 3.5 inch steel driveshaft with 4.0 inch aluminum rear driveshaft. This requires installation of a revised fuel tank skid plate for vehicles built before 1/15/2001 equipped with the 4X4 Off-Road package.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
  #4 (permalink)
Old 04-03-2003, 06:57 PM
Rockledge's Avatar
Quote:
Originally posted by rockledge
.......which is about 12' or so from the yoke itself.
Just to correct a typo, I meant to say 12 INCHES (12") NOT 12 feet (12').
__________________
Ford Pics
  #5 (permalink)
Old 04-03-2003, 09:51 PM
WXboy's Avatar
OK, dumb question: Where exactly is the slip yoke located? Does the rear drive shaft connect to it at the transfer case? Or is it something that is between the t-case and rear diff? And what exactly is it's job? How will it function when it works normally?
One last thing: How much is a 4" aluminum drive shaft selling for these days?
__________________
  #6 (permalink)
Old 04-03-2003, 11:13 PM
Rockledge's Avatar
WX, I sent you a PM.
__________________
Ford Pics
  #7 (permalink)
Old 04-04-2003, 08:55 AM
WXboy's Avatar
Thanks Rockledge and Ken for the info. After I do this greasing on the slip-yoke, how long can I expect it to last before I'll have to do it again? Any idea?
__________________
  #8 (permalink)
Old 04-04-2003, 09:28 AM
Rockledge's Avatar
After you do it one time you'll see that it really is not that difficult a task. Because of that, I'm probably going to do mine every 15-20K, whether I feel it needs it or not.
P.S. I used brake cleaner and compressed air to get all the old grease off the splines and yoke. Worked great.
__________________
Ford Pics
  #9 (permalink)
Old 04-04-2003, 09:39 AM
katdaddy katdaddy is offline
katdaddy is starting off with a positive reputation.
Thumbs up Will that common driveshaft problem destroy anything?
Guys, can you send me a "how-to" to do this?
Thanks,
Kevin
__________________
1998 Denim Blue 4x4 SuperCab
4.0L
P265/75R15 Uniroyal Laredos
  #10 (permalink)
Old 04-04-2003, 09:48 AM
Rockledge's Avatar
Kevin,
Sent you a PM.
__________________
Ford Pics
  #11 (permalink)
Old 04-04-2003, 02:45 PM
Thanks Rockledge,
This will provide me some entertainment this weekend.
__________________
4.0L
  #12 (permalink)
Old 04-07-2003, 11:37 AM
WXboy's Avatar
katdaddy....did you do this to your truck this weekend? Just curious if it solved your problem too.
__________________
  #13 (permalink)
Old 04-08-2003, 09:25 AM
Talking Will that common driveshaft problem destroy anything?
Didn't get the opportunity this past weekend. Hope to the coming weekend. I'll post my results as soon as I get it done.
__________________
4.0L
  #14 (permalink)
Old 06-18-2003, 08:20 AM
pete214 pete214 is offline
pete214 is starting off with a positive reputation.
Rockledge,
Could you send me a copy of that pm? I've got a '98 3.0, auto, short bed, regular cab w/42,000 mi.
Pete214
PS. I'm from CT also.
  #15 (permalink)
Old 06-18-2003, 11:40 AM
Rockledge's Avatar
Hello pete214, welcome to Ford Truck Enthusiasts!
Since you're from CT, I will post a link to it for you:
Driveshaft Lube
Be sure to save a copy of the PDF file to your hard drive!
__________________
Ford Pics
Tags
04 , 1998 , 2000 , change , changing , drive , driveshaft , ford , issues , piece , problems , ranger , shaft , tauras , thump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
