Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 06-18-2003, 01:01 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile is a name known to all CowboyBilly9Mile is a name known to all CowboyBilly9Mile is a name known to all CowboyBilly9Mile is a name known to all CowboyBilly9Mile is a name known to all CowboyBilly9Mile is a name known to all
Will that common driveshaft problem destroy anything?
I've got the slack in the driveline condition too and it worries the heck outta me. To add to it, there is a "ting" sound which occurs when you first take off, and most often happens after changing directions. After a post on this most thought it was a u-joint or the slip yoke and this was good, as this validated my thoughts on these parts. But after replacing these items and greasing the slip yoke nothing changed. Darn! The good news is that I won't (probably) have to worry about these items causing problems for many miles to come; the bad news it that I'm worried about reliability. I'd hate to be 300 miles from home and have something fail on a cold snowy night.
In my search to find answers I came across a handful of TSB's concerning the yoke which is bolted onto the transfer case. I have not been able to locate the full content of these TSB's, but the jist of them seems to be removing the yoke, cleaning it, reinstalling it using some special adhesive/bonding agent and torquing the nut with a new, higher torque. Has anyone tried this and did it make a difference?
As for the question concerning what the slip yoke does, it allows for the driveshaft length to change in response to the rear axle moving up and down. If you picture holding the truck vertically and then were able to lower the rear tires downward, the driveshaft length needs to increase; the slip yoke allows this.
On another note, I've heard that these transfer cases have a chain inside of them. Is this true and if so, is anyone aware of them developing slack or if they have flat out failed? Thanks.
  #17 (permalink)
Old 06-18-2003, 03:22 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE. Ken00 is gaining momentum as a positive member of FTE.
If you need to see the entire TSB send me an email with the Ford numbers.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
  #18 (permalink)
Old 06-18-2003, 03:29 PM
pete214 pete214 is offline
pete214 is starting off with a positive reputation.
Thanks to Rockledge. Ken00, CowboyBillie9Mile needs J-002/98 issued on 1/13/00 and revised on 2/7/00.
  #19 (permalink)
Old 06-18-2003, 03:35 PM
Ken00's Avatar
I need the Ford number(s), it should be formatted like 00-28-10, alldata lists them this way.
__________________
Ken
  #20 (permalink)
Old 06-18-2003, 04:45 PM
Ken,
You found me out! But isn't a Mazda really a Ford in sheep's clothing? Or does it loose something? Anyway, the TSBs are 0300202 and 0300100R in Alldata's Mazda-speak. But they are one of only two issued in July '02 and one of three issued in February '00, so they shouldn't be too hard to separate fron the rest.
Thanks,
Pete
  #21 (permalink)
Old 06-18-2003, 10:16 PM
Ken00's Avatar
Check your mail Pete. Glad to see that your out of the closet, LOL, I consider them Fords.
__________________
Ken
  #22 (permalink)
Old 06-19-2003, 05:39 PM
GRB GRB is offline
GRB is starting off with a positive reputation.
Is this a continuing problem? I've got a new B4000 4X4 and it clunks when I press the clutch and again when I release it, most noticable shifting 1st to 2nd, and 2nd to 3rd. If I press the clutch slowly, it's quiet. It sounds like free play in the drivetrain.
  #23 (permalink)
Old 06-19-2003, 07:19 PM
Ken00's Avatar
A clunk when you first taking off is common, when pressing the clutch in isn't.
__________________
Ken
  #24 (permalink)
Old 06-20-2003, 01:39 PM
Quote:
I'm between a rock and a hard point on the numbers. I got them by clicking on Recalls/TSB'S at the upper right corner of this screen; there were four of them and none are in the required format. However, one of them is 962417 so maybe 96-24-17 would work. It's dated 11-18-96 and the subject is "Powertrain - Driveline, pinging/creaking noise in driveline when engine torque is first applied to driveline". All four have the same title so I suspect that Ford revises/updates the info in the TSB. Thanks in advance for checking on this.
  #25 (permalink)
Old 06-20-2003, 03:44 PM
Ken00's Avatar
That is one on ping/creak in the drive line but I think its been updated to 99-16-01. 01-11-11 is the one on thump/clunk. If you need them send me an email, your email is blocked otherwisE I would have sent them. Remind me of the numbers.
__________________
Ken
  #26 (permalink)
Old 06-20-2003, 04:11 PM
GaryJ GaryJ is offline
GaryJ is starting off with a positive reputation.
FWIW, I am trying to track this problem down and found a resource some might be interested in. There is a "subscription" to the Ford TSBs that Motocraft sells based on time.
For $10 you can have access to every TSB for every Ford since 1988 for 3 days. Other rates are available for longer times, but 3 days should be plenty to d/l everything you would ever need...
Click on me!
I am a closet Mazda owner myself...
  #27 (permalink)
Old 06-23-2003, 02:40 PM
Piercepierce69 Piercepierce69 is offline
Piercepierce69 is starting off with a positive reputation.
Thumbs up Will that common driveshaft problem destroy anything?
Hello guys and gals. I just wanted to put my two cents in and explain what my experience was with the driveshaft thump. At first I thought that I had a broken or worn transmision mount or motor mount. After concluding that that was'nt the problem I thought it was something in my rear end diff. .........nope that was'nt the problem. After reading this thread there was no doubt left in my mind on what was causing that anoying thump thang on my truck. The next day I went to Autozone and bought some mobil one synthetic grease. I took the driveshaft off (took about 45 min because I had to use a closed end wrench) If you have a 12 mm 12 pt socket you could probably do it in about 10 min. After getting the driveshaft off, I took it apart at the slip joint and cleaned it well. It was my impression that there was'nt enough grease in there in the first place but there were no signs of any ever leaking out. Im not sure what the recommended amount of grease to put in there is but I put a ammple amount of the synthetic grease in there after I cleaned it well. After all was said and done I put it back together, assuring that it was exactly the way it was before I dissasembled it and replaced it on the truck. Waaala........ Test drove the truck and absolutely no more thump. I made sure to drive it hard to make sure that all that grease I put in would'nt leak. So far so good. Thanks guys for saving me about $600 in repairs that did'nt need to be done.
2000 ford Ranger 4x4 off road 4dr.
  #28 (permalink)
Old 07-05-2003, 08:50 PM
alancp alancp is offline
alancp is starting off with a positive reputation.
can someone tell me if i have to purchase the boot clamps from the ford dealer, or if maybe NAPA would have them. i also need to buy the clamp pliers also.
thanks alan
  #29 (permalink)
Old 07-05-2003, 11:11 PM
Schucks sells band clamps that you can use. They are actually made for CV boots. They also have a little tool for installing.
NAPA also probably has them.
  #30 (permalink)
Old 07-06-2003, 12:45 AM
I was actualy able to salvage the original clamps when I did my truck but I would be prepared to replace them with new ones. You can buy them at Autozone. I have heard some people say that they have used hose clamps or zip ties.
Tags
04 , 1998 , 2000 , change , changing , drive , driveshaft , ford , issues , piece , problems , ranger , shaft , tauras , thump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
