Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
LinkBack Thread Tools
  #196 (permalink)
Old 07-17-2007, 08:16 AM
FlameOut is starting off with a positive reputation.
Ok, thanks Still couldn't get the link to work though. Must be hit or miss
Sponsored Links
To remove this ad, register today!
  #197 (permalink)
Old 07-18-2007, 08:00 AM
asmith68 is starting off with a positive reputation.
Thanks for the link. That helps a lot.
  #198 (permalink)
Old 07-18-2007, 08:46 PM
RangerRuss is starting off with a positive reputation.
Take the part numbers with you to Ford to get the grease for the splines. Local parts dude around here could not find it without the part number. Also, two good-sized zip ties suffice to secure the boot - no real need for the metal clamps and special tool to tighten them....
Russ
__________________
2002 XL 2.3 Automatic
1998 Contour Zetec 2.0
  #199 (permalink)
Old 06-05-2008, 09:54 AM
baddmove's Avatar
baddmove is starting off with a positive reputation.
Hey Rock....do you have a link to do this to my BII driveshaft? mine is the CV one but not quite the same as the Ranger one?
__________________
89 EB bronco II 2.9
A/T A/C - daily driver
  #200 (permalink)
Old 06-07-2008, 11:12 AM
D-Line is starting off with a positive reputation.
Quote:
Originally Posted by jc2566 View Post
OK guys, I notice that this thread started waaaaaaaaaaay back in I believe 03 so my questions is on my 01 Ranger AT, 4x4, Supercab, what would be the majority consensus on correcting the driveline thump when taking off?
1: Remove the driveshaft and grease or
2: Have the drive shaft replaced with the 4 inch aluminum one?
In my experience you are not missing much with the 4" alum driveshaft. I bought my 01 XLT Off Road new therefore had the driveshaft replaced via the TSB listed earlier with the aluminum one. The same issue has been back multiple times. Realistically, the only way to fix the problem is to follow the directions provided by Rockledge and lube the slip yoke. I do it every 20000km. I've been doing it since my ESP ran out at 160000km. The truck now has 267000+km
  #201 (permalink)
Old 06-07-2008, 12:09 PM
Rockledge's Avatar
Rockledge has a very good reputation on FTE.Rockledge has a very good reputation on FTE.Rockledge has a very good reputation on FTE.Rockledge has a very good reputation on FTE.
Quote:
No, I haven't come across one, but I think the principles are the same, i.e., making sure you mark things beforehand to help you put it back together the way it was, and making sure you clean the splines real good, etc. There might be some instructions in the Haynes Manual for your BII for lubing the drivehsaft.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
