my 55 still overheating! please healp guys - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 08-27-2011, 02:15 AM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
Quote:
Originally Posted by Lance Hogan View Post
I knew the ported/manifold vacuum statement was going to ruffle a few feathers as this is a very misunderstood concept.
Ask Truxx1956 about the carb mods I did this summer at the GSM F100 Run. He gained 5 mpgs by me adjusting his step up springs (Edelbrock 1406) and moving his vacuum line from port to manifold.
http://www.ford-trucks.com/forums/10...00-run-12.html
By connecting your distributor vacuum line to manifold vacuum you pull vacuum at idle which advances your timing. At idle, you are at a very lean condition. By advancing one's timing at idle, this provides adequate time to burn the fuel during this lean condition (lean condition = more time need to burn fuel). The benefits of using manifold vacuum are cooler running temperatures and better mpgs. I am over simplyfying this confusing concept, but one can read a better detailed description in the following site which does a pretty good job of explaining this (post #19 from C9):
Ported or manifold vacuum? - THE H.A.M.B.
I am not going to get into a pissing contest over this issue. This is a suggestion which the OP can try or not. If fordman doesn't want to try my suggest that is ok.
Lance
I'm a bit miffed at the closing statement you left at the end of your post here. "I'm not going to get into a pissing contest here" Why the hell was that statement called for?? You think me or any others are in here to pick fights? That statement wan't called for... Here's a SHOCKER for you....
I took 2-3 HOURS and read each and every post on that HAMB thread as well as a couple other links within that thread. Information is golden, and unlike your asumption of me, I'm a bit more open minded, willing to learn new things every day. I see the points, and wouldn't mind revisiting this theory on a couple other rigs I own. I even copied and pasted the large and informative posts to a word document so i can later re-review it. Defintely a good read and worth experimentation.
Here's my issue.
1. In the past, every time I've tried to use manifold vacuum for the dizzy, on a FORD, the damn thing diesels like a locomotive... TOO MUCH ADVANCE, Pre-ignition, even witht e RPM backed down. That would be WHY manufacturers installed anti-dieseling valves/switches on carbs back in the 70s. To cut off the air/fuel supply... only way to stop the dieseling. I understand their reasoning too... keep things hot to burn cleaner for emissions purposes. I get that.
2. The whole time I'm reading these posts they keep saying that "advancing the timing at idle causes the engine to run cooler" That may be BUT- it contradicts what you propose in #2. To me it doesn't sound right as Pre-Ignition = Detonation which leads to buildup of excess heat. This could be just realitive to engine load... but have seen issues 1st hand in non-load situations.
3. You missed another point that was made. It was brought to attention that some of the 70s distributors (especially ford) didn't have enough mechanical advance to make up for the lack of the ported vacum if one were to hook up to manifold vacum. In other words, the distributors mechanical advance was designed to run along with the ported vacuum advance. (two advances combined) You loose that ported advance when you switch to manifold vacuum therefore you'd have to add more mechanical advance to achieve the 'all in' advance number you needed at higher rpms (under acceleration) or atleast until you started to pull your foot out of it and the manifold vacuum caught back up again.
Bottom line is, reguarding this subject, just as they stated in their articles, every car is different and this may not work for everyone or their application. I found it EXTREMELY informative and definately will be doing some future expiramentation on a couple of my rigs to see if they do net better results. I see the theory and it makes sense, but it needs to be put to practice to see if it actually works. I'll be trying that soon.
Thank you for sharing that article and I again ENCOURAGE everyone to read it. Very good info.
  #32
Old 08-27-2011, 06:42 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
Originally Posted by fordmanforlife246 View Post
Hey guys I've got good news! I went ahead and changed my tstat again!!! And my truck will run at about 220-230 and stop there! So it doesn't continue to get hotter and hotter anymore. But now I need to figure out how to get her to run a little cooler cause that's too hot. What should a 302 run at in about 115 degree weather? Anyone know? At night time I run about 205.
like Wayne said, maybe there is a problem with the gauge/sender setup. You shouldn't see 20 degrees difference day vs night.. On my green truck, even tho the sender was supplied by the gauge seller, the gauge was off 25 degrees and I had to add a resistor inline to recalibrate it. the laser temp gauge helped me find and do that change..
Sam
  #33
Old 08-27-2011, 07:29 AM
lexcoe's Avatar
lexcoe lexcoe is offline
lexcoe is starting off with a positive reputation.
The laser temp gauge is a great idea that will tell the real story John
  #34
Old 08-27-2011, 09:54 AM
carnut122's Avatar
carnut122 carnut122 is offline
carnut122 is gaining momentum as a positive member of FTE.carnut122 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by sdetweil View Post
I use one of the laser temp tools. cheap at Harbor freight and great for telling temps on all kinds of things.. (in to the rad, out from the rad. exhaust temps, ..., trailer tire temps)
Sam
That's even better. I bought one of those too and threw it into the tool box-I have totally forgotten about it.
  #35
Old 08-27-2011, 02:17 PM
fordmanforlife246 fordmanforlife246 is offline
fordmanforlife246 is starting off with a positive reputation.
My electric fan is giving me trouble. Goin to get a 6 blade 17" flex fan for 10 bucks
2003 Super Crew how much is it worth to you guys? texaskid22 1997 - 2003 F150 7 11-30-2014 06:10 AM
overheating issue on 85 f150 351 windsor Ranman028 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 07-10-2014 12:19 PM
351 Cleveland FJ45 Cruiser - Overheating and electrical issu CozmoNz 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 35 08-02-2011 01:45 AM
Overheating 66 F100 240 6Cyl Plz Hlp forgedbyfire 1961 - 1966 F-100 & Larger F-Series Trucks 26 05-01-2011 10:14 PM
Overheated 96' 351W Here are the symtomes what do you guys think? stonecrusherbronco 1987 - 1996 F150 & Larger F-Series Trucks 15 11-16-2010 09:40 AM
Tags
1955, 1997, 55, blown, cap, f100, f150, flex, ford, gasket, head, heater, hook, hose, overheating, squirtting, wan, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
