Blue spring upgrade instructions - Ford Truck Enthusiasts Forums
Old 08-24-2011, 06:51 PM
IT_Dude IT_Dude is offline
IT_Dude is starting off with a positive reputation.
I've been searching and found one or two things that talk about the blue spring upgrade, but I couldn't find anything with pictures. Can anyone point me in the direction of a post or other site that has pictures of the swap? From what I've read, it's not that hard, but I would do a lot better with pics.
thanks
Old 08-24-2011, 08:46 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
heres a pic of the housing it sits in
when you undo the 4 bolts hang on tto the cover the spring will push it out
and it sits in the bottom half
good luck not to bad a job
Old 08-24-2011, 09:03 PM
autonoz autonoz is offline
autonoz is starting off with a positive reputation.
Remove the air cleaner housing and inter cooler pipe and pull the radiator hose out of the way. Remove the fuel filter and use a turkey baster to get fuel out. If your replacing cover as well as the spring remove the fuel line. Take the four screws out making sure to hold the cover so the spring does not push it out. Remove the fuel line fitting from the old cover and put it on the new cover. Utilize the new parts and reverse the order to install.
Old 08-24-2011, 09:15 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Old 08-24-2011, 09:52 PM
BLADE35's Avatar
Great writeup stuff like that shure helps Sean
Fuel filters replacement Actechnician 71 6.0L Power Stroke Diesel 5 08-27-2015 11:03 AM
Thinking of Blue Spring upgrade on my 6.0 PSD Daz00Excursion S. California Chapter 13 08-06-2014 11:10 AM
blue spring upgrade?? tofargone 6.0L Power Stroke Diesel 18 03-05-2014 06:04 AM
Blue spring part #? lakewood 6.0L Power Stroke Diesel 16 05-16-2012 12:13 AM
"Blue spring" vib1 6.0L Power Stroke Diesel 5 03-28-2012 03:16 PM
Tags
04, 60, blue, f250, f350, filter, ford, fuel, kit, needed, sping, spring, tools, update, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
