'04 F150 idle issue
'04 F150 idle issue
greetings to everyone,
I've been a member for a while now but only lurk when I need info. and for that this site has proved to be very useful.
now I'm at the point where I need some help. I have an '04 F150 that has started having some idle issues as of yesterday. it has stalled on me twice but only when the a/c is on. it also has an erratic idle with the a/c on. once I turn it off idle is smooth. it only stalls when I'm at a stop with the a/c on, not when it's in motion with the a/c on. but like I mentioned above, it has only stalled twice, but the erratic idle is there always when the a/c is on.
where do I start? can anyone help? I'm ignorant when it comes to these newer Ford engines. any help will be highly appreciated.
--carlos
--carlos
Check this link...... P0506 Idle Air Control System RPM Lower Than Expected - DTC Code
Probably just a good cleaning is needed.
I don't think you have an IAC, but if you do, that is better. Not sure when Ford stopped installing. Remove the IAC and clean it good. Soak the inside of the throttle body to clean it as well. You don't need to remove the throttle body to clean with spray. Remove the little red hose that comes with the TB spray as you don't want it to fly off and into the TB.
Please show your lab reports that support your statement or any FMC lab supporting statements concerning plastic degradation and feel free to copy and paste your report here. I anxiously await your reply so I don't jack up my trucks.
Thanks,
John
Mine is acting very similar to Pony's. Rough idle and stumbles/stalls at low engine speeds like stop lights and turning into the driveway. Can't use the a/c except at highway speed.
I have not had a chance to get the codes on it but will tonight.
Anyway, I replaced the fuel filter (very dirty!), air filter and spark plugs. The air filter was not terribly bad and the spark plugs were not fouled but looked somewhat lean with a lot of erosion and pitting on the electrodes and straps. The engine starts easier but the problem is still there.
I was going to clean the throttle body but the Haynes manual suggest not cleaning with a spray solvent as the throttle body and it's components are coated with a substance that is to prevent crud from sticking to it. So, I didn't clean it.
The engine is a 4.6L with 80,250 miles on it.
