6.0 PSD Oil pressure switch blow out!!! - Ford Truck Enthusiasts Forums
Old 08-24-2011, 02:16 PM
dacaptain dacaptain is offline
dacaptain is starting off with a positive reputation.
Post 6.0 PSD Oil pressure switch blow out!!!
Just replaced the HPOP seals and the o-rings under the valve covers that cause the no start issue when hot, also did an EGR delete kit. got done drove down street, noticed slight boost increase. Truck felt as thought it wasn't getting enough air or fuel and almost like it needed another gear. I went about a mile and all of asudden pressure dropped, got back and oil was pouring out of switch. replaced it, checked all connections and went again. Everything was fine, drove about 60 miles towing this AM and same thing happened, felt like it didn't have enough air/fuel again under heavy load, hard acceleration ( 20-25 PSI of boost)?????? PLEASE HELP stuck right now.
Thanks for any help.
Old 08-24-2011, 06:48 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
welcome to FTE
so everytime you throw a new oil pressure switch when you drive it blows it out
IDK but it does have a LPO regulator
did you do anything to your HPOP and STC fitting??
Old 08-25-2011, 08:26 AM
I replaced the fitting on the HPOP with the updated one in the kit. It does have a regulator. Had it towed to my friend @ Ford last night. I'm a mechanic, but not a big diesel guy, I tow all day fore work so I need it fixed ASAP I borrowed a truck. I'm waiting on a call from them. I will post a detailed explanation of what I did and the solution tonight.
Thanks for the info and welcome.
Old 08-25-2011, 07:10 PM
O.K. Ford has no clue what is wrong. They installed a new oil pressure sensor and oil, ran it and it was ok. They proceeded to install a pressure gauge and take readings, pressure @ 90 psi @ 1800 rpm. No explanation why, new sensor did not blow in their possession. ford told them to install a sending unit (waste of time & money) Ford Tech. has no answer?? The saga continues...
Old 08-25-2011, 07:58 PM
BLADE35's Avatar
Quote:
an oil pressure sensor that keeps blowing is not a normal problem
I troll around here alot and this is the first time Iv heard about this problem
hopefully one of the techs can comment on the problem
it does have a LPO regulator maybe its not working right and building LPO to high IDK
Good Luck with it
My 2006 Ford F250 6.0 will not stay running andy101 6.0L Power Stroke Diesel 4 05-04-2015 05:56 AM
6.0 problems. high egts. high boost psi kd0nfq 1999 to 2016 Super Duty 2 08-21-2014 06:43 PM
94 Explorer with wierd problem Redneckfordf2502002 Explorer, Sport Trac, Mountaineer & Aviator 10 06-13-2014 10:20 AM
low boost after about a mile or so also speedometer quit busabuggy 6.0L Power Stroke Diesel 23 11-02-2012 01:26 PM
Tags
2003, 2004, 2006, 60, 6o, diesel, ford, oil, preesure, pressure, psd, readings, sender, sensor, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
