Miscellaneous Ford 460 Leftovers from an E350
Category: Accessories
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude, Fit, S2000, Motorcycles
Item Condition: MA
Engine: Part suitable for gas truck
These are mostly all from an 85 E350 RV, unless indicated.
Metal air/vacuum lines with valves as shown
Air pump injector lines with valve, good shape.
C6 dipstick and tube
Misc hard vacuum lines and fittings.
Coil bracket. From a small block I think.
Unknown tube (what does this thing do anyway?)
Heater hose fitting + tube.
Cont.
2 belt fan pulley.
Three belt crank pulley.
Dentside alternator harness. From 79 F100 with OEM ammeter. Not perfect, as seen.
OEM Holley 4v from 85 E350
Throttle linkage from 79 F100. Bent and modified to work with an Edelbrock carb.
2 belt fan pulley.
pauli3wood
975
12-17-2022 04:49 PM
FrankGRUN
02-22-2019 04:07 PM
Blue79F350
19
05-28-2010 02:27 PM
