C4 Trans Fittings - Ford Truck Enthusiasts Forums
C4 Trans Fittings
Old 08-23-2011, 10:32 PM
davewave649's Avatar
davewave649 davewave649 is offline
davewave649 has a great reputation on FTE.davewave649 has a great reputation on FTE.davewave649 has a great reputation on FTE.davewave649 has a great reputation on FTE.davewave649 has a great reputation on FTE.davewave649 has a great reputation on FTE.
C4 Trans Fittings
Im looking to replace the trans cooler lines on my C4. what size fittings should be used to replace the ones being used now? The current metal lines are 3/8" OD
Old 08-24-2011, 04:05 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
What's the C4 from?
Old 08-24-2011, 12:44 PM
I dont know because it was installed by a PO the number on top of the trans is 7E102978
Trans lines need some ideas Scoop531 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-24-2013 09:28 AM
e4od line fittings on trans. brad7.3 1994.5 - 1997 7.3L Power Stroke Diesel 7 03-23-2009 10:22 PM
C-4 Trans cooling line fittings gifuneod Clutch, Transmission, Differential, Axle & Transfer Case 3 05-10-2007 01:19 PM
FMX to C4 DPhillips Clutch, Transmission, Differential, Axle & Transfer Case 3 02-23-2007 09:58 AM
c4 trans cooling lines keithredfirebird 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-10-2006 10:56 PM
Tags
1972, c4, cooler, fittings, ford, line, size, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
