Aluminum Trim Anodizing Remover ?
on
Somebody wrote me about some Anodizing remover that was talked about a while back. I just went ahead and reposted it in case anybody else was needing some. I haven't been in contact with either place for a couple of years, but this is where I have bought before. The place in NC most recently. Phil
..........a readily available Anodizing remover. I had bought some a
few years ago, but could no longer find it. Well this past weekend I finally ran across a vender that sells it. It's the same stuff I bought before that worked so well. It's from a place called :
RGS Abrasives Inc.
1246 W. Webb
DeWitt, MI. 48820
517-669-8848 or 888-725-4538
E-mail <RGSBuff1@GTE.Net>
A jar about the size of a beer can is $10,
and that's enough to do a whole car if you don't spill or waste it.
(It takes just a small amount to make a gallon of solution, and you can use it over and over ) They also sell a full line of other buffing supplies.
Village Buffing Supplies
Boyd & Reba Hardin
902 East 22nd. St.
Kannapolis, NC 28083
Phone - 704-933-0084
Fax - 704-933-4180
E-mail - villbuff@vnet.net
Link - www.Villagebuffing.com
RGS Abrasives Inc.
1246 W. Webb
DeWitt, MI. 48820
Boyd & Reba Hardin
902 East 22nd. St.
Fax - 704-933-4180
on
This stuff makes a nice consistant liquid mix. You DIP the parts in a bucket or plastic pan and after you rinse it off, it leaves a nice smooth finish that polishes out nicely. You can save this stuff and use it over and over also. Not a bad deal for the money.
Good luck,
Good luck,
on
monroe hardin
01-17-2000 12:19 PM
