more progress - makeshift engine crane
a few more parts off the half tons, and a motor back on the ground
the trucks arent the easiest to move around, and I dont want to make a mess in front of the garage, but the crane wont roll on dirt.......
heres the solution!!
Ford to the rescue
empty!
Ford to the rescue
empty!
Received 4,130 Likes
on
Id love to have the Flattie, its going to be pretty when your done with it, but its your tractor that brings back memories from the sixties when i used an older version of it to load sand and gravel at a building supply place. People would drive up with there station wagons and I had to fit the bucket inside the back window and drop a load then watch as they drove off draggin the mufflers,LOL good times. Good luck on your motor.
She is a 1969 Ford industrial, with a Ford 745 loader. It can also handle the backhoe attachment, but all I have is a weight box there right now.
The extra piece on the top of the bucket was put there by the PO, for forks. I have left it for now because there is a hook on it I have put to use. They used to use it for hay and manure (drain holes in the side)
Also have a fork attachment that replaces the bucket, that I will be putting to use for cab and box removal.
(picking up chains today)
z31freakify
34
12-12-2022 07:52 AM
KrenzyRyan
62
12-20-2013 10:04 PM
2000ca250
24
02-21-2013 02:04 PM
