56 dash repair - Page 2 - Ford Truck Enthusiasts Forums
56 dash repair
Old 08-25-2011, 11:18 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
Originally Posted by ben73058 View Post
Hey Sam,
I went back & looked at the pics of your dashboard. It doesn't look that bad - I've attached my prize dashboard for perspective on the true meaning of hacked up.
Ben in Austin
yowser!
Sam
Old 08-25-2011, 04:04 PM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
Quote:
Originally Posted by sdetweil View Post
thanks for the vote of confidence on the repair.. hate flat surfaces that are really visible..
on the column, its a generic from CPP, from EBAY, another one for sale here Universal Chrome Shift Steering Column With Tilt 30" | eBay
I don't think this one has a detent plate to change..
Sam
Huh... that's the same exact column i bought, but i only got one shift arm (the bent one) and the OD indicator. Weird. I'll have to get ahold of them and see if I can get the other indicator.
BTW- Yeah hands down Ben's dash is the winner for being grossely hacked. I bet the whole thing is warped to beat hell and will probably never be straight again it its life. Freakin hacks... just too bad.
Old 08-25-2011, 04:32 PM
sdetweil's Avatar
I only got one shift arm but two plastic pieces.. the second one was buried in the foam padding
Sam
Old 08-25-2011, 08:43 PM
Dano78's Avatar
CRAP! Good thing I haven't thrown the box or padding away yet. I'd better take a closer look... That's for pointing that out!!! Thanks Sam!
Old 08-26-2011, 09:58 AM
sdetweil's Avatar
on the replacement (first was dented), the extra site glass and the lower arm were in a little box, pic below
Sam
Old 08-26-2011, 10:03 AM
sdetweil's Avatar
well, I'm going to try to repair the hack.. patches cut and ready to weld..
Sam
Old 08-27-2011, 12:32 AM
HEAVY100's Avatar
HEAVY100 HEAVY100 is offline
HEAVY100 is gaining momentum as a positive member of FTE.
Is this column going to fit my 56 with stock front end ? I am planning on doing the front end but my shifter is not that great and I want to put a billet steering wheel so I figured might as well get this column .
Old 08-27-2011, 04:42 AM
Dano78's Avatar
Sam- I think you'll be more than pleased witht he results. Looks like you're off to a good start. I got faith in ya! Oh and btw- didn't find any extra PRND21 in my box. Also realized mine was not from CPP but another outfit. Bought it a while back and got confused where i got it from. Box, packaging, etc.. looked the same as yours tho. Will just have to source another indicator.
@HEAVY100-- I guess that all depends on what steering you're running. I have stock suspension but am using the Toyota p/s conversion. Seems to work great so far, got it mounted up tonight. Just need to tackle the shift linkage now...
Old 08-27-2011, 06:31 AM
sdetweil's Avatar
Quote:
like Dano said, you will have to do some work at the steering box. the stock setup is a solid bar from wheel to box..
what steering box will u be using?
Sam
Old 08-27-2011, 06:33 AM
sdetweil's Avatar
maybe a call to CPP can get u the glass? I plan on an OD tranny so will be using mine..
Sam
Old 08-27-2011, 10:58 AM
sdetweil's Avatar
well, maybe its repairable!
Old 08-27-2011, 11:16 AM
HEAVY100's Avatar
I have no idea what steering box to use ,I need ideas. I want to install power steering as well .
  #28
Old 08-27-2011, 11:37 AM
sdetweil's Avatar
with the stock spring suspension, I think the only choice is a toyota power steering box.. it fits about exactly where the stock steering box is located,
and there is an arm available to connect to the stock draglink.
then u can use any steering column above it that has some adapter from its shaft style to the Toyota box input shaft.
Sam
  #29
Old 08-27-2011, 12:06 PM
HEAVY100's Avatar
thanks for the info Sam
-Meir
  #30
Old 08-27-2011, 12:45 PM
sdetweil's Avatar
-Meir
my pleasure, and if u make 4 more posts then the FTE search engine becomes available for you (at 25) (they block out new users to prevent robots from driving the search engine)..
there are plenty of folks that have done the Toyota PS mod, and there are good pics and descriptions too..
Sam
WTB Ford 300 Inline 6 Forged Crankshaft bigfootsurfin WTB - Ford Trucks & other vehicles 6 05-19-2015 05:13 AM
1968 f600 dash, is it welded in? Rusty_Old_F250 Large Truck 2 07-30-2014 01:43 AM
WANTED 53-56 crossmember under bellhousing jeffscott01 Ford Truck Parts for Sale 1 04-21-2014 12:08 AM
Might be a deal for somebody Rusty_Old_F250 1947 and Older Ford Trucks 6 03-18-2014 08:09 AM
EZ Wiring Dash Panels norfolknova 1961 - 1966 F-100 & Larger F-Series Trucks 0 01-27-2014 07:27 PM
Tags
1955, 55, 56, dash, dashboard, f100, ford, original, rebuild, refurbish, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
