Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Minnesota Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Minnesota Chapter Join Chapter, Leader: fordpower88
  #1 (permalink)
Old 08-23-2011, 11:27 AM
Fosters Fosters is offline
Garage is empty, add now
Fosters is gaining momentum as a positive member of FTE.
Truck buying time... need advice
Hey everyone, long time no... err.. post. Anywho, I'll get straight to the point. I sold my excursion to a friend who offered 500 bucks more than I paid for it 3 years ago. I'm now looking for a replacement truck. I found a 97 PSD/zf5 fairly cheap and cosmetically challenged, and would like to have a mechanic look at it before I pick it up.
It runs decent, doesn't blow me away as far as power goes - seemed on par with the excursion at best, after it warmed up. It does put out a fairly good amount of blue smoke on startup, which I read that it could be as simple as injector o rings, or as bad as piston rings or bad injectors... Does anyone know of a shop or mechanic, preferably in the shakopee/south west area, that I could take this thing to and have it looked at, just so I know what I'm getting myself into?
Thanks!
__________________
2001 F250 Reg Cab 4x4 V10 - 285s and 5star tuned
2004 mach1 mustang, holding the garage floor in place.
2003 Mercury Marauder - keeping the mustang company
2000 Excursion Limited 4x4 V10 - 285s and 5star tuned - Gone
2004 F150 XLT screw 4x4 5.4 - 2.5 leveling kit, 34.5" BFGs - Gone
  #2 (permalink)
Old 08-23-2011, 01:31 PM
DieselCamper01's Avatar
DieselCamper01 DieselCamper01 is offline
2001 Ford F-350
DieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to behold
Wish I had a good recommendation for you. Hopefully someone chimes in that knows someone in that area. Good luck with the truck.
__________________
Jay
2001 F350 Lariat CC LB 4X4, Various mods
http://www.roadsidehelpnetwork.org/
  #3 (permalink)
Old 08-24-2011, 05:29 AM
HP junkie's Avatar
HP junkie HP junkie is offline
2004 Ford F-250
HP junkie has a very good reputation on FTE.HP junkie has a very good reputation on FTE.HP junkie has a very good reputation on FTE.
Could be a glow plug issue as well. I don't know of any but hopefully someone will. Good luck!
__________________
Cory
'04 F250 6.0 SRW CC LB 6-speed 210K, Edge juice w/attitude, open exhaust, blue spring.......
'05 Freestyle Limited 3.0 CVT 109K
  #4 (permalink)
Old 08-24-2011, 12:30 PM
msmenne17's Avatar
msmenne17 msmenne17 is offline
msmenne17 is gaining momentum as a positive member of FTE.
Blue Smoke would be oil burning. From what I've read, injector o-rings are common. This seems likely, especially since it goes away as the engine warms up. The o-rings expand and seal up when they get warm. I've got a 96. It could be something else as well, but o-rings are cheap and relatively easy to do. Check in the 94.5 - 97 forum. There is alot of good info over there.
White smoke would indicate unburnt Diesel (glow plugs). I know mine smokes when I start it up. The colder it is, the more white smoke I get. Even one glow plug can do this.
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
__________________
Michael
Quote:
Originally Posted by equium View Post
Tell him the lug nuts on your truck require more torque than his car puts out!
  #5 (permalink)
Old 08-24-2011, 09:43 PM
Yeah, I went through that forum a bit.. Found out that the old body styles also never hit 400k miles displayed, and just roll back to 300k... so makes me wonder how many miles are on this thing. As far as the blue smoke is concerned, the second time around it started much easier and with a lot less blue smoke; so it very well could be the o rings. There were a few other things on the truck though that turned me off and I think I will pass on it. The fan blower doesn't seem to work, only got a hint of cold air out of the AC. Also, under the hood i found a cardboard wrapper from a stop leak product in the engine bay... along with a plastic funnel. I don't mind extra accessories, but the stop leak stuff worries me.
It's at Apple Suzuki if anyone wants it; 97 f350 crew 4x4, 337k, surprisingly little rust on it, none on the underbody/suspension, just a bit on the body, and sporting some bling bling 20s with good tires on it. they have it listed at 4500 bucks.
I appreciate the help
__________________
  #6 (permalink)
Old 08-25-2011, 08:26 AM
2001 Ford F-350
Sounds like walking away is best in this case. Good luck in the hunt!
__________________
Jay
  #7 (permalink)
Old 08-25-2011, 09:59 AM
msmenne17's Avatar
I'd definitely walk away from the stop leak stuff. Who know what that crap has done to it. You could very well be ending up with a truck that costs 2X-3X what you paid for it.
__________________
Michael
  #8 (permalink)
Old 08-25-2011, 10:03 AM
Quote:
Yeah, that's what I thought... If I didn't depend on it this winter, and had time and space to work on it, I'd pick it up in a heartbeat. At the very least, it would be an awesome start for a cummins swap - having the manual tranny would mean basically no electronics...
__________________
  #9 (permalink)
Old 08-25-2011, 11:21 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
2007 Ford F-250
My Garage
MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.
He Festers, go buy something with a 6.0 in it.
__________________
Chris - Avid Winter Hater
2007 F-250 XLT 4x4 CC SB 6.0 PSD - ARP, IPR GEn2 EGR Delete, 4" turbo-back, no muffler, no cat, 6.4 banjo bolts, SCT X3, Tenney 270A alt, coolant filter, air bags, Ranchos, etc.
1994 Mustang GT - HCI, MM suspension parts, etc Novi2k waiting on the shelf
Hope & A Prayer Motorsports
  #10 (permalink)
Old 08-25-2011, 11:34 PM
Quote:
I'm passing up a 7.3 because of possible reliability issues... not gonna touch a 6.0 anytime soon :P Once I'm in az, maybe I'll get a 6.4 or something, for now I just want a winter beater that can tow more than my cherokee
__________________
  #11 (permalink)
Old 08-26-2011, 09:10 AM
MisterCMK's Avatar
2007 Ford F-250
My Garage
Did that clean 7.3 on TCS ever sell?
__________________
  #12 (permalink)
Old 08-26-2011, 03:01 PM
the 2wd one, yes. The 4x4 that LTD has, no, but that's a non turbo. I can pick up a mod motor f150 with more hp and torks.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
