trouble with my new (to me) f150
hey all,
i just came back from a trip through yosemite with my 1994 super cab f150 4x4 351 3speed with od. it has a camper shell. going on the flat highways it was just fine, but once i got to the mountains, i started to have some problems that i'm hoping you will be able to help me diagnose.
going up gentle inclines i had a hell of a time keeping it in od: the truck just didn't seem to be able to keep up speed so i would have to shift to 3rd, either by turning the od off, or by gassing it. on the steeper inclines i even had to shift to second (by putting the pedal to the floor) and even then the truck couldn't go that fast. it felt like my parking brakes were on (they weren't) or i was pulling a trailer ( i wasn't). it got so bad that today it overheated. at one point i was having a hard time overtaking trucks that were actually pulling trailers. needless to say, that was embarrassing.
another symptom was when it shifted from 2nd to 3rd, or from 3rd to od, and the rpms were at the lower range of the gear i shifted into, the truck would start shaking. the shaking would stop when i got it to downshift to the lower gear. i'm not sure this makes sense, so please let me know and i'll try to elaborate.
i'm getting pretty poor gas mileage, like 10-13mpg. i have knobby all terrain tires.
i had the transmission checked by a couple of transmission shops and they said it's okay.
i recently changed the spark plugs, wires, cap and rotor.
please help; i want to use this truck to take my family and me and a trailer to baja california and back.
thank in advance!
thank in advance!
You may be able to borrow one from a place like Auto zone, or buy one under 30. bucks. Warm the truck up, turn her off. On top of the intake there should be a capped vacuum port, hook the gauge there and restart the motor. Look over here:
Reading your vacuum gauge
Vacuum Engine Timing | MILEPOSTS Garage (Tech Tips) I do this, but a timing light may be better for you, just ignore the carb talk.
thank you blue rebel, i changed the wires one by one. so i didn't number them (the replacements were not labeled). but if i did in fact mix them up, how do i check for that? i know the cylinder numbers, but i'm not sure i remember them on the dist. cap.
i suppose a shop could look at it and tell me pretty easily.
JstoneF150
2004 - 2008 F150
02-19-2015 08:57 AM
wulfaz713
04-23-2009 10:53 PM
rebel_ford4x4
11-10-2005 11:38 PM
