Truck stalls going around right hand corner. Any ideas? - Ford Truck Enthusiasts Forums
Old 08-23-2011, 01:35 AM
Ak Ford Man's Avatar
Ak Ford Man Ak Ford Man is offline
Ak Ford Man is starting off with a positive reputation.
I got a 1980 f150 with the 4.9L I-6. the fuel pump has been converted to electric.
When i go around a right hand corner, the truck dies. once u straighten out, it will roll start its self and keep going. any ideas what it might be?
Old 08-23-2011, 05:41 AM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
I remember reading of one owner having that problem (not sure if it was a 6 or V8)........his float level was too high & was flooding the engine cornering.
Old 08-23-2011, 06:29 PM
Eddiec1564 Eddiec1564 is online now
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
Check to see if the carb is not loose on the intake. My friend's F150 would die turing right and a with a quick left wiggle would keep on running! We found the carb is falling off the intake on turns!
Old 08-23-2011, 07:23 PM
planehunter's Avatar
planehunter planehunter is offline
planehunter has a good reputation on FTE.planehunter has a good reputation on FTE.planehunter has a good reputation on FTE.
Are you sure you have enough gas in the tank? Sucking air as you turn maybe?
Old 08-23-2011, 08:12 PM
billt28's Avatar
billt28 billt28 is offline
billt28 is gaining momentum as a positive member of FTE.billt28 is gaining momentum as a positive member of FTE.
Only make left hand turns. No seriously, check the carb for tightness, they're infamous for loosening themselves from the intake manifold. Also check the float level as Ken suggested.
Old 08-24-2011, 01:58 AM
Ive had trouble with is coming loose before. the truck has done it for a long time. I'll check the float.
Bad wheel bearing or something else ? DanielT28 1994.5 - 1997 7.3L Power Stroke Diesel 8 06-27-2014 10:14 AM
2009 XL Odometer Lights Issue Cozmos201 2009 - 2014 F150 8 11-28-2011 10:02 AM
Grinding when turning to the right Superred2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 02-13-2011 10:22 AM
2004 Explorer vibration edford1 Explorer, Sport Trac, Mountaineer & Aviator 3 12-11-2010 09:17 PM
Gas cap leak MikeSmith 1961 - 1966 F-100 & Larger F-Series Trucks 17 09-19-2006 03:35 PM
Tags
19801986, 1997, 54, car, corner, corners, dies, expedition, explorer, f100, f150, ford, hand, making, stall, stalls, truck, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
