1991 Ford F150 not starting after gets hot
Old 08-22-2011, 11:09 PM
cmf1978's Avatar
cmf1978
cmf1978 is offline
I have a 91 f150 that after running for a bit and it getting hot does not want to start. i have to let it cool down for like 30 minutes before i can get it to start. When I take off the gas cap there is a big release of gas vapors. any clues as to what it might be or how to fix this? also the oil pressure drops when hot as well.
Old 08-22-2011, 11:18 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Welcome to FTE.
What *does* happen when it won't start?
Does the engine crank when you turn the key? Or no?
The oil pressure dropping on a warmed-up engine is an indication that it's worn out.
The vapor noise, something is up with your EVAP system - Evaporative Recovery.
Old 08-23-2011, 02:20 AM
cmf1978's Avatar
cmf1978
cmf1978 is offline
the fuel pump seems to not work and maybee i have vapor lock not sure
Old 08-23-2011, 02:50 AM
Slip ford man's Avatar
Slip ford man
Slip ford man is offline
Best thing to do first, is see if there are any stored codes. Your problem could just as easy be electrical vs fuel related. These older trucks are known to suffer such problems, so pull the codes first, and see what you got there. Here is a how to
Ford Fuel Injection » How To Run a Self-Test
Old 08-23-2011, 02:55 AM
cmf1978's Avatar
cmf1978
cmf1978 is offline
Originally Posted by ctubutis
Welcome to FTE.
yes the engine cranks but does not ignite
i pull out the fuel pump relays and cool them off and then it will start but the engine itself does not overheat
an indication of what when the oil pressure drops??
any ideas for the EVAP system?
Old 08-23-2011, 04:28 PM
IJRoorda's Avatar
IJRoorda
IJRoorda is offline
When you cycle the key on, can you hear the fuel pump run to prime the rail?
F250BlackChrome
08-18-2010 03:52 PM
jg32879
08-10-2010 06:53 PM
Tom.Lapham
06-14-2009 06:51 AM
hasali1
15
10-13-2006 06:53 PM
oldbuck
02-02-2004 02:30 PM
Quick Reply: 1991 Ford F150 not starting after gets hot
