wont stay running
wont stay running
I have a buddy who has a 2005 ford f250 with the 5.4. he wanted me to ask you guys since he knew i was a member here , and that you guys were a lot of help. His truck wont stay running. if you start it and drive for 10 minutes it will die. he says that you have to jump it to get it to start back , and it will fire right back up. run for 10 min and die again. he has replaced the battery and alternator and now hes at a loss. any help would be great thanks.
Sorry, odds are you wouldn't have the equipment to do that. Instead, kill the vehicle when its running fine, then take the pressure at the fuel rail.
Run it again until it dies by itself, then take the fuel pressure again.
If the second pressure is a lot less than the first, you have your problem identified.
Oh yeah, he definitely has electrical problems. But I'm guessing they developed because the car died on him and he kept cranking when his electrical system was marginal to start with.
I don't know if its true today, but it used to be that you didn't need a battery to run a car, inasmuch as the alternator/generator would produce all the juice needed to for the motor to run, indefinitely.
I'm a little hard pressed to believe that both the old and new alternators were bad to the point that the engine is dying after ten minutes. Hell ,a fully charged battery will run a vehicle for 90 minutes or so without an alternator.
So yes, he has electrical problems, but I suspect the underlying problem could be something like a clogged fuel filter......
Tartersauce53
15
07-11-2017 06:49 PM
chuck L.
15
06-08-2005 06:56 PM
