Strong gas smell, very bad mpg's
2 weeks ago after filling up I noticed a very strong gas smell that followed me. At about a half tank and only 45 miles later (this is unusual) the smelled seemed less and less by the time I was near E the smell was nearly gone totally.
Not sure where to start on this...
Is the engine running poorly?
You could get under the truck and look along the frame for gas dripping, also pop the hood and look for leaks. If you don't find anything, then remove the air cleaner and start the engine up. Look inside the barrels of the carb (assuming it has a carb) and see if gas is dripping into the engine.
What year of truck and what engine?
Yes, we certainly need to know the year. The earlier trucks (80 - 84?) had steel fuel lines with short pieces of fuel hose connecting them. These hoses are usually in very poor shape after all these years, and many times leak right through the wall of the hose. And, since the tank sits higher than the fuel pump on many of them fuel leaks even while the truck is not being driven.
Later models used plastic lines to replace the steel/rubber combo, but still retained a hose into the fuel pump. This one, too, can easily leak.
Mine was cracked and dry rotted and the spring clip on the end of the line leading to the fuel tank was loose!
1/4'' vacuum hose at 1 ft length, re-bent the clip, and a new screw-tightened band and it looks like new. Gave me some added security too.
I'd hate to be on a long trip, miles away from an auto-parts store when that thing decided to bust (which is more than likely where it'd happen, knowing my luck. I like to go hunting).
That rubber line is the first thing I replaced under my hood when I saw it. It comes off the hard line against the frame near the steering column and connects to the fuel pump, which from there is a hard line off the fuel pump (I guess for engine heat? ) that runs back to the carburetor.
Also, you said "hard line", but was it metal or plastic? If metal then there are several more pieces of fuel hose under there that are the same age as the one you replaced. In my experience they should all be replaced.
Yes, that's one of the failure points. But, I hope you really didn't use vacuum line as it won't stand up to gasoline. Surely you mean fuel line?
That's another thing to point out for the OP... buy FUEL line. It'll be marked on the hose if it's fuel line. The difference (I'm assuming) is so that your line won't melt like Styrofoam when exposed to the gasoline.
Mines a hard metal line. I guess I'm going to get back under the truck and check for other "soft" lines tomorrow.
IMO... they all should've been hard.
All I ever GOT was fuel line when I asked for VACUUM line at the auto-parts places.
In '84, I think, Ford changed to the plastic lines and did away with all the fuel hose except for the piece at the mechanical pump. So, those systems don't have the same problems as the others.
As for the ones with steel lines, the # of hoses depends on whether or not you have dual tanks. If so, you have a hose from the top of both tanks to the first metal line; then hose from the ends of those two lines into the selector valve; one hose from the selector valve to the front hard line; and then the hose into the fuel pump.
If you, like most of us, aren't using both tanks you can simplify things by plumbing around the valve with a piece of hose. And, btw, while under there put a see-thru plastic fuel filter in the hose just after the valve to save the pump.
Insert sound effects from Tim Taylor in the 80's TV sitcom Home Improvement:
Huh?????????
I know some guys out here don't run both but I certainly do.
'course I don't have the return lines and such to deal with, it's all pretty simple.
Huh?????????
Of the three I've owned, my Dad's, and others I've talked to around here, none have two working tanks. For some it was the valve that quit. Others appear to have had the hose go bad and it leaked so they stopped using it. I'm seriously considering taking my side tank off to simplify the soon-to-be dual exhaust system. No way do I need more than 19 gallons of fuel.
ford4her
01-28-2010 10:47 PM
cozzajoe
03-28-2008 02:35 AM
four-sixty-power
08-06-2005 02:17 AM
daggerNC
11-01-2004 05:34 AM
cwtex
12-19-2003 02:46 PM
